Old 04-10-2018, 08:49 PM   #1
Magoo2
Default Oil pan sludge
Anyone have any thoughts on cleaning oil pan sludge without removing pan. My thought was to drain oil and fill pan with diesel and let it sit. Then drain out the diesel. I don't want to run an oil/diesel mixture with the engine running afraid of circulating the sludge. The car has been sitting over 10 years. I'll pull the pan if I have to but trying to avoid removing the pan.
Magoo2 is offline   Reply With Quote
Old 04-10-2018, 09:34 PM   #2
michael a
michael a's Avatar
Default Re: Oil pan sludge
Pull the pan
Sent from my iPad using Tapatalk
michael a is offline   Reply With Quote
Old 04-10-2018, 09:55 PM   #3
KR500
KR500's Avatar
Absolutely Pull The Pan. Its the only correct way!
KR500 is offline   Reply With Quote
Old 04-10-2018, 10:03 PM   #4
SeaSlugs
SeaSlugs's Avatar
yup - easy to do on a model A compared to a modern.
drain it, drop it, drop it again to knock out the baffle, clean it till you can eat off it, snap baffle back in after checking for pitting in dipper tray, not a bad time to check bearign clearances, new gaskets and away you go.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 04-10-2018, 10:14 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
I tried the best way possible, and it can't be done. You must pull the pan and valve cover to clean the sludge. Be sure to drop the pan upside down on the grass to removed the dip tray.
Old 04-10-2018, 10:30 PM   #6
Magoo2
Thanks everyone! I thought that was going to be the answer but was looking for an easy out. You would think after 66 years I would know better. Thanks again. Do you guys think I should rebuild the oil pump while I'm at it?
Old 04-10-2018, 10:57 PM   #7
PC/SR
My dad used to drain the oil, put in a gallon of kerosene and run the engine for about 5 minutes. This on an old International PU. Claimed it kept the engine clean, and I imagine it did, but I have never done it and never would. As stated, drop the pan, and check the bearing clearances while you are at it. Put 4x4s under the front tires--the extra height makes things easier.
PC/SR is offline   Reply With Quote
Old 04-11-2018, 07:57 AM   #8
SeaSlugs
SeaSlugs's Avatar
Sure cant hurt - at minimum drop it and clean the screen and check for scoring. Alot of times the acids that build up over the years break that big spring on the bottom of the pump so check over that spring carefully for pits.
Old 04-11-2018, 08:55 AM   #9
DKnapp
I would not try the kerosene routine. I once did that with a '76 Ford van and it was not too long before a rod bearing went out. The kerosene loosens up all the grit and sludge and it circulates thru all your cylinders and bearings causing a lot of wear. Save your engine -DROP THE PAN AND SIDE VALVE COVER.
DKnapp is offline   Reply With Quote
