05-06-2018, 08:00 PM | #1 |
seized rear hub
Need to pull rear brake drum from the axle. I have put maximum torque with a genuine Ford rear axle puller, have also tried heat and puller, air impact gun with genuine puller.
My next trial will be a air driven carbide cutter to cut a relief on the hub. Any advice appreciated. |
05-06-2018, 08:03 PM | #2 |
Re: seized rear hub
I have never heard of a genuine Ford rear axle puller. Would you post a picture?
Charlei Stephens |
05-06-2018, 08:16 PM | #3 |
Re: seized rear hub
Charlie asks a great question. You want to use the puller that grabs the snout of the hub,not the studs on the drum.
05-06-2018, 08:23 PM | #4 |
Re: seized rear hub
I call the puller that grips the snout "genuine" as it is designed especially for Ford hubs.
05-07-2018, 12:34 AM | #5 | |
Re: seized rear hub
Charlie Stephens |
05-07-2018, 12:40 AM | #6 |
Re: seized rear hub
05-07-2018, 01:57 AM | #7 |
Re: seized rear hub
or less damaging,heat the hub next to the keyway when the puller has the max load on it,
that will expand the hub,and free it up Lawrie |
05-07-2018, 02:46 AM | #8 |
Re: seized rear hub
Try applying max torque, back off, apply again, and repeat a few times. Plus a good hit with a heavy hammer. Also could try leaving it for a while at max torque.
Have, to ask, though, what is "max torque" for a puller? Mart. |
05-07-2018, 06:38 AM | #9 |
Re: seized rear hub
I have always found heat to work. I just pulled a pinion gear off a model A driveshaft and when heated it popped of and went flying across the shop.
John |
05-07-2018, 07:00 AM | #10 |
Re: seized rear hub
If the vehicle is still operational, you could try this trick. Put the axle nut back on, but leave it a turn or two loose. Go out and drive in a few "figure-eights" in the parking lot and see what happens. Quite often, this will break them loose.
05-08-2018, 12:19 PM | #11 |
Re: seized rear hub
OK have the generic puller that pulls on the inner ring of the hub. next best thing to a genie KRWislon puller.
Pull with puller -- did not work Pull with puller and rap on center of puller --did not work Pull with puller heat and rap on center of puller -- did not work Pull with puller, heat, rap on center with bigger hammer BFH !!! Any good ideas welcome before I get my 4" carbide cutter and cut the SOB off as I try to save the axle. Last option will be to pull rear axle and get after it with the cutting torch. If you have any other ideas call me at 541-990-7377. Deadline is to make it to the big meet in June. Thanks, Paul |
05-08-2018, 01:58 PM | #12 |
Re: seized rear hub
You could have a safety hub inside the drum keeping it from coming off. I've gotten some very tight drum/hubs to come off tapered axles w/o having to cut anything. I'm also wondering what you are calling "max torque". I've occasionally used a length of pipe to extend a strong bar/cheater bar to get more torque. When it finally popped, it sounded like a 9mm gun fired near my head.
05-08-2018, 02:09 PM | #13 | |
Re: seized rear hub
Charlie Stephens |
05-08-2018, 02:39 PM | #14 |
Re: seized rear hub
I predict "BINGO" re: safety hubs.
05-10-2018, 12:12 AM | #15 |
Re: seized rear hub
After trying all methods suggested and tried It finally gave it up and came off. Only after using my die grinder and six 3" discs and cutting all but the axle away from the threaded end of the axle to the area where the tapered ended. I think I found the reason for hanging up. The key that is in the keyway slot was in backwards (the square end was inboard). Only an 82 year old dufus could do something this simple. Now will break down the Columbia, install a new axel, drum, and get ready for Dearborn.
05-10-2018, 12:30 AM | #16 |
Re: seized rear hub
