Old 07-17-2015, 09:55 PM   #1
Drive Shaft Dave
Default front fender to splash shield bolts
What size fasteners are used for the front fender to splash shield? 1930 coupe ,early.
Drive Shaft Dave is offline   Reply With Quote
Old 07-18-2015, 05:07 PM   #2
blgitn
blgitn's Avatar
Default Re: front fender to splash shield bolts
The dozen I just removed today are 1/4" diameter, 20 threads per inch, 3/4" long with a flat washer on both sides and a lock washer under the hex nut.
R/ Roger.
blgitn is offline   Reply With Quote
Old 07-18-2015, 08:55 PM   #3
blgitn
blgitn's Avatar
Like this one:
Old 07-19-2015, 12:59 AM   #4
Drive Shaft Dave
Thank you for the reply.
Old 07-19-2015, 10:52 AM   #5
Terry, NJ
Terry, NJ's Avatar
This may be all wrong, but I think somewhere I read that these bolts were 12/24. It's a little smaller than 1/4"(about 7/32) and much harder to find, but if you're like me and try not to modify things any more than you have to, you'll like knowing this. HF (Or Edsel) liked this thread and used it in several places. Most notably to hold the hood pivot sockets on the cowl and radiator. All 3 of my cars had 10/32s in their place.
Old 07-19-2015, 08:41 PM   #6
taffrail
taffrail's Avatar
I have a 30 tudor and a 30 ccp and both splash shields screws are 1/4x28.
taffrail is offline   Reply With Quote
Old 07-20-2015, 09:19 AM   #7
Terry, NJ
Terry, NJ's Avatar
Taffrail, I believe you are right with the front splash shield. Mine (4) are 1/4 28 too. That is the splash shield under the radiator. I believe he is referring to the splash shields by the running boards and the screws/bolts that attach them to the back end of the fender. Correct me if I'm wrong.
Terry
Old 07-20-2015, 12:36 PM   #8
mrtexas
mrtexas's Avatar
Aren't they 1/4 bolts with smaller head on them then standard?
mrtexas is offline   Reply With Quote
Old 07-20-2015, 05:20 PM   #9
blgitn
blgitn's Avatar
Both ends on mine take a 1/2" wrench.
They might be 28 tpi, but I thought I counted ten threads in half an inch.
R/ Roger.
