07-01-2017, 01:16 PM | #2421 |
Re: What I Did on My Lunch Hour
Gremlins.
07-01-2017, 01:32 PM | #2422 |
I think you might be right... Maybe I shouldn't park it next to a Studebaker...
07-01-2017, 01:33 PM | #2423 |
Steam? If it's not on the ground, or in the engine or rad or exhaust...
07-07-2017, 06:00 AM | #2424 |
Hi Jeff, I've been without internet, phone and cable TV service for the last three days (Florida storms)... but now I'm back. To answer your question, steam would still have to exit the engine for it to lose water. Someone had suggested putting dye in the coolant, to be able to see where it might be exiting. That'll most likely be my next attempt to solve the mystery... maybe this weekend... meanwhile, the Flathead fun continues.
07-08-2017, 05:02 AM | #2425 |
Could be going out exhaust while you are running and you would never see it.Pressure test
07-08-2017, 07:58 AM | #2426 |
07-08-2017, 09:13 AM | #2427 |
Good luck.
After all these years, the flatty can still get you to scratch your head and make you think. It helps offset senior moments it's the cars way of providing you marvel mystery oil for your brain.
Thanks Andy 1952 F1 |
07-08-2017, 10:42 AM | #2428 |
Yup, this car is really starting to aggravate me... I just took her out for a run, got caught in a Florida downpour, pulled her into the garage and the overflow is pushing out foam... I did see some water on the top of the distributor, it was warm and had a faint odor of antifreeze... The rest of the engine compartment was wet as well, complements of the rain... Now I'm wondering if water is escaping from one or both water pumps at the pulley shaft...? Thankfully I've got a set of rebuilt water pumps so... maybe later today I'll swap them out... I am going to see if I can get some dye to put in the radiator first...
07-08-2017, 02:04 PM | #2429 |
I went to the auto parts store and got some dye to put in the cooling system in the '39 CS. According to the instructions, after the car is brought up to normal operating temperature (between 170 -190 degrees), any fluid leakage will be visible under a UV light... Following the instructions (which is normally what I do after every other attempt fails). I still can’t detect leakage from anywhere. I'm not having any fun... Next step... gasoline and a match... Time for a Car-B-Cue...
07-08-2017, 03:22 PM | #2430 |
Ouch!!.... wow, your are pissed.....mix a cocktail, grab a snack, get a comfortable chair.... sit there and stare at for awhile...... either the solution will come to you or you'll scare into straightening out on its own..... I hope you get it fixed... Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
07-08-2017, 03:43 PM | #2431 |
I'm going out to get a bag of marshmallows to roast over the fire...
07-08-2017, 04:01 PM | #2432 | |
07-08-2017, 04:15 PM | #2433 |
LOL... Not with that early fuel injection... I'd rather have two leaky Carters on it...
07-08-2017, 04:20 PM | #2434 |
Smart move there........you just saved yourself $6-8K.......or more! DD
07-08-2017, 05:15 PM | #2435 |
I have a friend that has a '57 Pontiac Convertible with factory fuel injection... Much more trouble that a couple of Holly's sittin' on a Flathead V8.
07-08-2017, 06:14 PM | #2436 |
Hey Vic: Time to get out of the garage, have a cool one and forget your problem for awhile, then at 3am you will awaken, study the problem, and devise a solution, Maybe even tomorrow at 3am. Good luck. Jim...
07-08-2017, 10:43 PM | #2437 |
Thanks Jim... I'll let you know.
07-09-2017, 04:48 AM | #2438 |
put a radiator pressure tester on it and it will tell you there is a leak
07-10-2017, 03:17 PM | #2439 |
I took a very enjoyable, albeit not topless, cruise this morning down to Sarasota to check out a '57 Ford F-100 for a friend of mine. I drove the '51 F-1 and it performed flawlessly... Maybe it cut me some slack because it's my birthday... The engine temp stayed between 160 and 180 degrees, cruisin' at between 65 & 75 MPH on the highway and sitting at just about every traffic light on the secondary roads. Even better, the F-1 did not burn a drop of oil... Best of all, my friend bought the[I] '57 [/I]F-100. I told him I'd be happy to drive it up to LI but, he didn't take me up on my offer... The '57 is a beautifully restored vehicle and it drives like a dream. I know my friend will have many years of enjoyment with the truck.
07-10-2017, 03:44 PM | #2440 |
Best wishes from the worldwide Cigar City Flatheads support group!
