Old 01-13-2023, 05:55 PM   #1
History
History's Avatar
Default Rear Motor Mount(Shim) ?
Both sides had this welded to the top, doesn’t look to be a crack repair/bridge. Can anyone tell me why this has been done? Can’t get my head around it unless it’s to mask a sagging frame for better drive train alignment. Any other thoughts or ideas??
File Type: jpg 05155E8B-D03E-4CA1-A155-23A0D192CAAC.jpg (63.1 KB, 136 views)
File Type: jpg 87053009-AE04-493B-8143-44673F3EC8C3.jpg (33.2 KB, 149 views)
History is offline   Reply With Quote
Old 01-13-2023, 06:58 PM   #2
Keith True
Keith True's Avatar
Default Re: Rear Motor Mount(Shim) ?
If the bolt holes are egged out to match,I would say to make up for a saggy frame.If they are not egged out,I would say it was done to make up for a badly worn flywheel housing.
Keith True is online now   Reply With Quote
Old 01-13-2023, 09:53 PM   #3
History
History's Avatar
Bolt holes are not egged. The piece that was welded is ford marked which is probably a coincidence, probably cut from an existing part? If you enlarge the 2nd photo you can see this.
Old 01-14-2023, 07:57 AM   #4
jw hash
jw hash's Avatar
if the frame sagging the throttle can hit the firewall. something is not correct.
jw hash is offline   Reply With Quote
Old 01-14-2023, 05:36 PM   #5
History
History's Avatar
Should the top of the frame be level the entire distance? With the engine out I believe I can use a laser level and see what kind of shape it’s in, I believe?
Old 01-14-2023, 05:52 PM   #6
Flathead
Flathead's Avatar
Frame should be level.
Flathead is offline   Reply With Quote
Old 01-16-2023, 11:01 AM   #7
Bob Bidonde
Bob Bidonde's Avatar
I suspect the mounts were shortened to make it easy to install an engine.
Bob Bidonde
Old 01-16-2023, 12:05 PM   #8
History
History's Avatar
I see your reasoning but the other side looks normal and same size except for the added piece. I think it probably for a sagging frame now. For others reference,,, you can’t use a laser level to check frame with just the engine and transmission out, still too much in the way.
