04-01-2021, 10:40 AM | #1 |
Clutch problem on 30 CCPU
I went out to move the Model A pickup yesterday, it started fine, pushed the clutch in and moved it forward about a foot. The clutch pedal went all the way to the floor, movement stopped. I checked underneath to make sure nothing was disconnected with the pedal etc and nothing obvious. I have not removed the floor to check through the inspection plate but thought maybe someone else had this problem in the past. The previous day, I drove the pickup for a coupe of miles with no problem. Any suggestions welcome.
04-01-2021, 10:51 AM | #2 |
Re: Clutch problem on 30 CCPU
Good Morning...This happened to me about 16 years ago with a 31 Tudor that I had just purchased...It turned out to be the clutch adjusting rod had broken...its a small piece, so you have to look for it...pull the clutch up and put a block of wood or something to hold it up and then go under the truck and look for the rod hanging on the end of the clutch...Ernie in Arizona
04-01-2021, 11:18 AM | #3 |
The operating arm could also be cracked thru the pin.
04-01-2021, 12:50 PM | #4 |
i had this happen and the arn on the clutch shaft cracked i could not see it but no clutch i foud it put new one on fixed
kevin 1930 Tudor |
04-01-2021, 06:54 PM | #5 |
Very common, here's mine. You are lucky it happened near the corral. Mine broke a few miles. I had to drive it home in second gear. Stoplights were fun...
04-01-2021, 07:23 PM | #6 |
04-02-2021, 07:39 AM | #7 |
Most may not know this yet however a new arm was just released and will likely be available from your favorite supplier. This one should be plug & play as-is as it is made from a better quality material. Here is a link to one supplier's listing;
https://www.snydersantiqueauto.com/P...EASE-SHAFT-ARM |
04-02-2021, 07:50 PM | #8 |
Thanks Brent. I just ordered one on your recommend. But I chuckle to myself whenever I buy a repro part (or original, for than matter) and pay more than $10 for it, since I bought my entire, original, complete, one-owner Tudor in 1961 for only $125.
