Old 07-05-2016, 07:59 PM   #1
Logan
Logan's Avatar
Default Tod's NEW WINFIELD test review
About a month and a half ago, Tod sent me one of his new Iron 6:1 winfield's to test. And there is only one word for it, AMAZING. I replaced my snyders 5.5:1 head with his winfield 6:1 and it was a world of difference. I have driven the car roughly 2800 miles since i installed it, and it has been wonderful. I even tested it from texas to colorado and back for the MAFCA national to give it a good loaded down higher RPM road test. And it pulled every hill better than i could have ever asked it to. I'm not going to get all technical, but the reason it had such an improvement over the 5.5:1 is because of the design of the combustion chamber the winfield's have. I still recommend the snyders 5.5:1 or 6:1 head, which Tod also Casts.
I did end up backing my timing off to about 24 degrees total advance for this head though. I wasnt getting any "pinging" from the increase in compression but after test driving it at 29 degrees advance, i could just tell it was too much. It pulled even better with that much advance, but i could feel/hear the pounding the cylinders were taking with that much advance. The people that understand what i mean with that last sentence will get what i'm saying. So at 24 degrees, it pulled my coupe fully loaded down with tools, parts, and clothes to colorado and back. While sitting on top of Ron Kelley's touring engines we cruised at a average of 68 mph there and back (often faster), with the motor never breaching 165 degrees.
I will say that i highly recommend this head, when it comes out in production. It wont be the only one that I own, I can guarantee that.
Cowtown A's
Logan is offline   Reply With Quote
Old 07-05-2016, 08:28 PM   #2
4port
4port's Avatar
Default Re: Tod's NEW WINFIELD test review
Are you running a Gary Bernard 4 speed overdrive, with 3.78 rear end ratio?
Remember when flying low inverted, down is up, and up can be expensive.
4port is offline   Reply With Quote
Old 07-05-2016, 08:50 PM   #3
tbirdtbird
congrats on the job!
did not know you had one of Tod's new goodies!
Agree with the advance you ended up with...we are using 23°
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-05-2016, 10:22 PM   #4
Logan
Logan's Avatar
Yes and yes. With 16 inch wheels and radials
Cowtown A's
Old 07-05-2016, 10:24 PM   #5
Logan
Logan's Avatar
Thanks Dave! We made it official today... It's going to be a learning curve though out the next year or so.
Cowtown A's
Old 07-05-2016, 10:32 PM   #6
tbirdtbird
you'll knock'em dead.....
i'll swing by with the wrecked slant someday.....
'31 180A
Old 07-05-2016, 10:42 PM   #7
Logan
Logan's Avatar
Sounds like a plan. The goal is to have 1-2 old cars in the shop at all times. Those being the complete build projects, while teaching them the modern body work also.
Cowtown A's
Old 07-06-2016, 04:36 AM   #8
waxhead
waxhead's Avatar
Thanks for the review
waxhead is offline   Reply With Quote
Old 07-06-2016, 06:09 AM   #9
Tod
I have 4 in the shop to machine right now, and I'm sure they are all spoken for. I will be making more soon.
I also posted a picture of the first aluminum block on my Facebook page. I may get to the point of taking a picture of the block sitting in the fixture and IN the machining center.
Tod
Tod is offline   Reply With Quote
Old 07-06-2016, 08:07 AM   #10
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
Tod
Tod, I would like to view your Facebook page but can't find it using the FB search function. What is you Facebook ID?
Thanks!
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 07-06-2016, 10:35 AM   #11
Tod
Thanks!
Just plain old Tod Buttermore.
Tod
Old 07-06-2016, 11:55 AM   #12
Thanks.
Bill Lee
Old 07-06-2016, 05:31 PM   #13
quickchange
quickchange's Avatar
Tod , What is the depth of chamber over the valves ? As head I was trying to use on our salt engine will need to have it relieved due too cam lift , Just doing some figures now , height . less gasket , less clearance etc , cam is 490 lift on both lobes, Thanks , Derek in a chilly NZ
quickchange is offline   Reply With Quote
Old 07-06-2016, 06:04 PM   #14
Tod
Chamber depth is .740.
Tod
