04-06-2015, 11:15 AM | #1 |
Emergency brake pawl replacement
The A I'm working on away from my house has a thin emerg. brake pawl. I bought a thick one. Can I change out the pawl without removing the floor boards. As I look at my A here at home, It seems like an easy task. As I try and remember the car I'm working, there seems to my weak mind to be something the blocks the removal of the pin?
04-07-2015, 07:33 PM | #2 |
Re: Emergency brake pawl replacement
Not much of a problem. There was some aligning to do. The thicker pawl stays in place. the emrg. brake works fine
04-08-2015, 08:13 AM | #3 |
Any chance of sharing your source for the thicker pawl? Just how thick is it?
04-08-2015, 03:50 PM | #4 |
Bratton's sells the thicker pawl. there are 5 versions. The car had a thinner one installed and the pawl would cock off line and miss the teeth.
04-09-2015, 06:23 AM | #5 |
Thank you.
I have to investigate my E brake handle assembly. It appears (to me) to be very loose, with a fair amount of sideways movement. It does not release well either. I know it's a replacement, because the old rusty one was in the back of the car. |
04-09-2015, 06:29 AM | #6 | |
Thanks Tom........ |
04-09-2015, 10:16 AM | #7 |
So...What I just learned, was the original emergency brake ratchet was 5/16" (0.3125) thick, and what's in the car is 1/4" (0.250) thick. The same thing with the pawl. I am ordering 5/16" ones.
