Old 07-11-2019, 12:46 PM   #1
ford31
ford31's Avatar
Default model a fan
does model a fan have just nut and cotter pin no lock washer
ford31 is offline   Reply With Quote
Old 07-11-2019, 01:17 PM   #2
chrs1961815
chrs1961815's Avatar
Default Re: model a fan
I believe it was just a castle nut, cotter pin, and the woodruff key.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-11-2019, 01:57 PM   #3
ford31
ford31's Avatar
thats what mine has
Old 07-11-2019, 02:06 PM   #4
30 Closed Cab PU
Thought I read somewhere, but can not now find, that sometimes a washer under the nut had to be used, if either by tightening down the nut you can not get the cotter in, or if the nut can not be tightened enough to prevent wobble.
And something about getting the tapers to match?
https://www.fordbarn.com/forum/showt...ght=fan+wobble
30 Closed Cab PU is offline   Reply With Quote
Old 07-11-2019, 03:01 PM   #5
Brentwood Bob
Also, the aluminum replacement fan needs a flat washer. A lock washer will Gaul the aluminum.
Brentwood Bob is offline   Reply With Quote
Old 07-11-2019, 03:43 PM   #6
Joe K
Joe K's Avatar
On repop water pump shafts there are ALL sorts of manufacturing inconsistencies. One of these is the position of the taper relative to the threaded retainer on the shaft. Some repop shafts NEED a washer between the fan and the shaft to get proper pre-load on the taper.
For a while there were issues with the aluminum fans with a taper apparently being done as part of the casting process - this was found unsatisfactory and now all these fans have a fully machined taper.
But- getting the tapers to marry and mate can still be a challenge.
Vince Falter has a good write-up of Fan/shaft issues worth reading by anyone who is past the "Ultimate" pump" level of technical acumen (i.e. it broke so replace it kind of mechanic.) http://www.fordgarage.com/pages/originalwpshaft.htm
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 07-12-2019, 05:00 AM   #7
Steves46
Steves46's Avatar
I think that may depend on individual situations. When I installed mine, The woodruff key, castle nut and cotter pin was only needed and the fan fit nice and snug.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
