Old 11-17-2019, 08:42 AM   #1
Tim R Hansen
Default Data plate rivet holes don't line up
Just purchased a data plate for the firewall on my late 31 Coupe. The rivet holes in the firewall don't line up with the holes in the repro plate. Holes are off by about 1/16" My firewall is not a re-stamp. Anyone run into this?
Tim R Hansen is offline   Reply With Quote
Old 11-17-2019, 09:08 AM   #2
Joop
Joop's Avatar
Default Re: Data plate rivet holes don't line up
Can you post a picture
Joop is offline   Reply With Quote
Old 11-17-2019, 09:24 AM   #3
Tim R Hansen
I can try but it will be difficult to show. The two bottom holes line up but the two top holes are both about 1/16 lower than the holes in the plate
Old 11-17-2019, 09:54 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
I had this problem when restoring my 190A. Rather than rework the original holes in the firewall, I pulled the holes in data plate using a rat tail file. Look closely and you can see the elongation of the holes. My hope is that a correct fitting plate will eventually become available.
Bob Bidonde
Old 11-17-2019, 10:00 AM   #5
Ed in Maine
I experienced this problem also. Like Bob has suggested, I elongated the holes and found that the heads of the rivets did cover the holes in the plate. You may have to elongate all four holes in the plate to get the fit you want. Ed
Old 11-17-2019, 10:44 PM   #6
SteveB31
SteveB31's Avatar
The file will work, but if you buy a good US made patent plate, they will line up perfect. Chinese patent plate won’t.
SteveB31 is offline   Reply With Quote
Old 11-18-2019, 09:26 AM   #7
GPierce
GPierce's Avatar
The plate I bought from Berts lined up perfectly.
https://modelastore.com/index.php?ro...&category_id=0
GPierce is offline   Reply With Quote
Old 11-18-2019, 10:52 AM   #8
SSsssteamer
SSsssteamer's Avatar
Ditto. For over 50 years, the repro data plates have had to have their drilled holes adjusted to match the firewall rivet holes.
SSsssteamer is offline   Reply With Quote
Old 11-18-2019, 08:52 PM   #9
Tim R Hansen
I made it work. Next time I go to Bert's first
Old 11-19-2019, 12:22 AM   #10
Charlie Stephens
Who do you recommend as a supplier?
Charlie Stephens
Old 11-19-2019, 01:40 AM   #11
cpf240
cpf240's Avatar
Where did you buy the I’ll-fitting plate?
No matter who the vendor is, I’d suggest calling and ask if one part is better than another. Places like Berts, Brattons, Snyder’s, etc will give you their opinion.
cpf240 is offline   Reply With Quote
Old 11-19-2019, 08:44 AM   #12
Benson
Benson's Avatar
Charlie Stephens
Berts Model A Center has the correct sized plates.
www.modelastore.com
With some parts there are several sources for parts and Berts has used the various parts and they know which ones are good and which are not so good!
Old 11-19-2019, 05:39 PM   #13
Oldbluoval
Oldbluoval's Avatar
Bert’s is a great source
Every time I tell someone and they don’t...... I get to use one of
My favorite phrases....
“I told u so”
Oldbluoval is online now   Reply With Quote
Old 11-19-2019, 06:13 PM   #14
Dean Lemoine
Dean Lemoine's Avatar
I bought one from Mike’s, it fit perfectly
Dean Lemoine is offline   Reply With Quote
