09-20-2011, 09:49 PM | #1 |
Auction Treasure or Auction Bust
Our local club held our annual Beauty and the Beast auction tonight. In one of the boxes of items I spotted this late 30-31 instrument panel. I have never seen one with this much detail. The ribbed area is well defined and is nickel plated not chromed. When I compare it to my older chromed panel the quality difference is readily apparent.
So is this an original or just a better repro part? Either way I think I got a treasure for 10 bucks.
Oklahoma City Model A Restorers Group. |
09-20-2011, 10:38 PM | #2 |
Re: Auction Treasure or Auction Bust
I'd say you did damn good for $10. Is it nickel over solid brass? At any rate it's a late 31 style with the line around the ribbed area.
JMO- It looks original from what I can tell. Post a pic of the backside- it'll yield more clues. |
09-20-2011, 10:50 PM | #3 |
I believe it is original, it appears to have the brushed Nickle finish.
There were some late 31 dash cups that were brass; check the back side around where the speedometer mounts and if it has a "B" stamp the metal is brass and most ideal. Ron |
09-20-2011, 10:51 PM | #4 |
It appears to be nickel over brass. I can see the brass tint on the backside but no B mark or other on the back. The dash that it will replace is a nice unit that is stamped "made in germany" on the back. The auction dash also does not have the off/on stamped on the ring.
09-21-2011, 04:59 AM | #5 |
I am of the opinion is is an older repro that was floating around during the 70's.
09-21-2011, 05:08 AM | #6 |
09-21-2011, 09:43 AM | #7 |
The dash with the "B" on it feels heavier then the others.
09-21-2011, 12:15 PM | #8 |
TIN CUP ...............
You got a REAL good buy ! Several months ago, I sold one, just like yours, on Fordbarn for $55.00. I must have been too cheap, as I could have sold about ten of them ! Mine was not brass ! MIKE Last edited by FL&WVMIKE; 09-21-2011 at 09:56 PM. |
09-21-2011, 08:52 PM | #9 |
Is the on/off plate correct or should it be blank?
09-21-2011, 09:17 PM | #10 |
Blank !!
09-22-2011, 07:11 AM | #11 |
As I recall, the brass dash will not have the line surrounding the area of the horizontal lines.
Not all dashes that are missing the line are brass, you need to find the B on the speedo reinforcement plate on the back. This is based on my observations and may be wrong as I have not spent any time researching this. |
09-22-2011, 09:54 AM | #12 | |
This is the original finish late '31 instrument pabel that I sold for $55.00 and wished that I had more ! MIKE CLICK ON PHOTO TO ENLARGE - Twice |
09-22-2011, 10:47 AM | #13 |
I have been told that the brass panels were used on the open cars. The other original instrument panels used on the mid 30-31 closed cars were copper plated steel, then butler nickle plated. This may not be absolutely correct but it is what I have either read or have been told. I have bought used instrument panels that had worn spots that showed a copper or brass like plateing under the nickle. The seller would usually point out the worn spot and say, see here this is an original brass panel! After checking with a magnet, would reveal that the panel was constructed of steel. Copper plateing is used as a primer to fill small imperfections in the steel panel before the nickle plating is applied.
09-22-2011, 11:42 AM | #14 |
My late 1931 U. S. Mail Truck was found to have a brass instrument panel when restoration began, and at the time I was in contact with a few other mail truck owners who also had brass panels.
09-22-2011, 12:54 PM | #15 |
"There were some late 31 dash cups that were brass;"
our MARC of Originality Coupe is a flat firewall car, April '31engine- it has a brass dash panel.
our next Model A is out there in the unknown...... |
09-22-2011, 01:00 PM | #16 |
I do not believe Herny used any imported parts for the A. As you can see on the panel it was made in Germany, this was an older reproduction panel
09-22-2011, 03:53 PM | #17 |
It looks exactly like the one I just bought.
09-22-2011, 03:54 PM | #18 |
The panel with the made in Germany stamp on the back is the older repo that the new panel will replace.
