08-09-2019, 03:50 PM | #1 |
Stumped by no start...
Helping a friend with a motor that didn't run for 30 years. He got it started on two occasions but the last one, it puddered down to a halt and we now cannot get it to even puff. I reset the timing which now gives a big smart spark, checked the plugs, fuel flow, and compression.... aha! 1-2-3 show 52-55lbs. Number 4 shows a big nothing. But even with a squirt of fuel into the carb or into the number one cylinder, it doesn't even puff. He did replace the head gasket but that seems a little unlikely doesn't it, with only maybe 20 minutes on the motor? And, would an engine not start if ONE cylinder has no compression? Signed, Stumped in Export, PA
08-09-2019, 04:35 PM | #2 |
Re: Stumped by no start...
It should start fine on three cylinders. Just check the basics fuel, spark, valve and spark timing. If all are correct it will start.
08-09-2019, 04:54 PM | #3 |
does it have an in line fuse at the starter?
www.whidbeymodelaclub.com |
08-10-2019, 05:24 AM | #4 |
No, there is no in line fuse at the starter.
08-10-2019, 05:41 AM | #5 |
Try starter fluid in the carb and see what happens. If he had the manifolds off, there may be a big leak.
08-10-2019, 12:16 PM | #6 |
08-10-2019, 12:22 PM | #7 |
So your going to keep is a secret on the problem with number 4??
