01-27-2019, 07:58 AM | #1 |
Varnish? on Huckster
What kind of finish do you Huckster owners put on the woodwork? Varnish? Spar Varnish? polyurethane? Urethane? Clearcoat? Oil rubbed?
etc? On initial coating and preservation and refreshing? Some of the wood on my Special Delivery project is cut, sanded, drilled notched and is need of preservatoin before assembly. kenp |
01-27-2019, 05:58 PM | #2 |
Re: Varnish? on Huckster
I have one of the Lentville A'S body on my huckster. It came with a finish already on it. But each year I try to put a coat of Armstrong "shine keeper" floor finish. This keeps the moisture from getting into the red oak. It is a clear type of coating. If I do it every year, it does a fair job of keeping the oak from turning black in spots.
01-27-2019, 06:04 PM | #3 |
Not sure what you would use on a Huckster, but I use good quality Spar Varnish on my truck bed, holds up extremely well if not parked outside all summer, for years.
01-28-2019, 01:33 AM | #4 |
Mix in this link are some good idea;
https://www.modeltfordclubofamerica.....php?f=2&t=472
I know the voices aren't real but damn they have some good ideas! |
01-28-2019, 07:53 AM | #5 |
Any finish that is exposed to the sun needs to have "SPAR" in the name. Plain varnish or other finish has no UV protection. Automotive clear coat can be applied to wood. It can be sanded and buffed to a high shine if that is what you want.
01-28-2019, 09:02 AM | #6 | |
