11-30-2017, 08:54 PM | #1 |
Floor board drawings
I have the drawings by Steve Watrous for the lower front floor board but it appears to have missing dimension. I have drawings form other sources but they are all missing this dimension.
Does anyone have the dimension that is hi-lited on the attached dwg. Thanks |
11-30-2017, 09:31 PM | #2 |
Re: Floor board drawings
If you cut it to 5 1/2 inches you will be really close. Here is the idea: The total width is 16 7/8. Looking at the left side, there are two measurements, one of 4 19/64 and one of 7 5/64, which appears to be very close to the line you are looking for. 4 19/64 + 7 5/64 = 11 24/64 = 11 3/8. With the total of 16 7/8 - 11 3/8 you end up with a 5 1/2. Which looks like where you would like to be.
11-30-2017, 09:36 PM | #3 |
6 9/16" (6.5625)
Good enough.. Isn't. |
11-30-2017, 10:23 PM | #4 |
5 11/16's
www.whidbeymodelaclub.com |
12-01-2017, 12:50 AM | #5 |
My notes agree with #4.
5 11/16. |
12-01-2017, 02:12 AM | #6 |
12-01-2017, 04:06 AM | #7 |
12-01-2017, 09:25 AM | #8 |
In the first drawing, lay a straight edge along the witness line at the top of the 4 19/64" dimension line and does not line with cut out in the center of the floor board.
Mike, thanks for the view showing the 5 11/16" dim. I'll add it to my drawing. |
12-01-2017, 05:28 PM | #9 |
Just cut a cardboard pattern that fits your car & make floor boards accordingly!
Bill Scissorhands
