Old 02-16-2019, 06:56 PM   #21
Angledrive
Angledrive's Avatar
Default Re: Double bearing pinion sleeve imstall
You would be far better to assemble both bearings and set the preload before you drop it in place, Sometimes I have to reset the preload after I insert it in banjo.
Angledrive is offline   Reply With Quote
Old 02-16-2019, 09:41 PM   #22
quickchange34
quickchange34's Avatar
Look inside the the case where the pinion lives there is a step there that the rear of the pinion race goes against . The front of the race is inline with the machine surface of the case in front.
quickchange34 is offline   Reply With Quote
Old 02-17-2019, 08:06 AM   #23
cederholm
cederholm's Avatar
Thanks guys - I have to research setting the pre-load.
cederholm is offline   Reply With Quote
