Old 08-17-2018, 05:51 PM   #1
Minn-Tex Lee
Minn-Tex Lee's Avatar
Default Shifter tower gasket question
I am replacing the tower and after making a new gasket for the tower / body surface I notice there is no gasket on the vertical surface where the two plungers slide in.
Is this correct or do I need to make a gasket for that surface?
Thanks
Lee
Minn-Tex Lee is offline   Reply With Quote
Old 08-17-2018, 05:53 PM   #2
redmodelt
redmodelt's Avatar
Default Re: Shifter tower gasket question
See Toms reply, I forgot the gasket between the transmission and bell housing.
Old 08-17-2018, 06:05 PM   #3
Minn-Tex Lee
Thanks for the quick reply, no problems with a leak?
Old 08-17-2018, 07:07 PM   #4
Tom Endy
Tom Endy's Avatar
There is a gasket that covers that vertical surface. It is the gasket that fits between the rear of the bell housing and the front of the transmission. It extends up and covers around the two shaft holes. The gasket comes with a transmission overhaul gasket kit.
I would make a partial gasket if yours is missing.
Tom Endy
Old 08-17-2018, 07:38 PM   #5
redmodelt
redmodelt's Avatar
Never mind Tom is right.
Old 08-18-2018, 09:24 AM   #6
Minn-Tex Lee
Thanks for the update. I feel better now.
Lee
Old 08-18-2018, 01:10 PM   #7
denniskliesen
denniskliesen's Avatar
I don't even use a gasket up there anymore, on either surface. I clean all mating surfaces dry, and smear a little Ultra Black on put it together. Never had a leak after that.
If you ever have your transmission out, I would highly recommend installing the transmission-seal-deal, or whatever it's called up on the inside of the bell housing, made by Mitchell.
denniskliesen is offline   Reply With Quote
