Old 07-16-2019, 07:28 PM   #1
hb32
hb32's Avatar
Default Cast steel vs aluminum crab distributor
Is one better then the other ? Why the different versions and is one more desirable?
hb32 is offline   Reply With Quote
Old 07-16-2019, 07:58 PM   #2
Brian
Brian's Avatar
Default Re: Cast steel vs aluminum crab distributor
Personally, I prefer the iron bodied unit. For one, the bore of the piston brake plunger is lined with a bronze bush
Old 07-16-2019, 09:16 PM   #3
pete rose
Steel was generally used on commercial ( truck) engines
Aluminium generally passenger cars.
pete rose is offline   Reply With Quote
Old 07-17-2019, 03:11 PM   #4
Kube
Kube's Avatar
Cast was 1942 cars and trucks.
Old 07-16-2019, 09:40 PM   #5
hb32
hb32's Avatar
Interesting
Old 07-16-2019, 09:48 PM   #6
deuce_roadster
deuce_roadster's Avatar
I usually see the cast iron ones in military surplus boxes. The bushing for the piston is nice.
Old 07-16-2019, 09:56 PM   #7
38bill
38bill's Avatar
Pulled a cast iron one out of a truck at the local junk yard some years ago. Just had Bubba rebuild it this spring and I'm running it now. He really likes the cast units.
38bill is offline   Reply With Quote
Old 07-16-2019, 10:17 PM   #8
hb32
hb32's Avatar
I have two aluminum and a cast. Presently the cast is installed and so far so good.
Old 07-17-2019, 06:01 PM   #9
Ian NZ
Ian NZ's Avatar
The cast iron distributors are the way to go the bronze bush in the vacuum brake gives a better reading to the worn aluminium vacuum brake housing. Every aluminium distributor i have worked on I have found the vacuum brake housing is worn and this applies to the early bell types too, more than the cast iron housing with the bush which could be replaced if necessary to give the piston better sealing.
Ian NZ is offline   Reply With Quote
Old 07-17-2019, 06:12 PM   #10
barnfind08
Can't be too hard to bore and install a bushing in the alum ones.
barnfind08 is offline   Reply With Quote
Old 07-17-2019, 06:55 PM   #11
hb32
hb32's Avatar
Interesting reading and good to know. Thanks to all for the excellent replies
Old 07-18-2019, 06:29 PM   #12
russcc
Fred hit the nail on the head, bore/hone the aluminum one, install a bronze bushing.
Old 07-18-2019, 07:03 PM   #13
Ian NZ
Ian NZ's Avatar
It would be a good idea, thats if you could buy bushes to fit.
