Old 05-19-2010, 11:48 AM   #1
Big Kevin
Big Kevin's Avatar
Default Spark plug questions....
Hi there.
What is the basic criteria for spark plugs to work well with a stock Model A? Would any 14mm spark plug work? Just got me thinking about when I go to swap meets and see those big boxes full of neat old spark plugs from manufacturers long since forgotten. Would be neat to see some old green stripe ACs or blue tops on the old banger. So would any 14mm work?
My blog:
http://bangerquest.blogspot.com
Big Kevin is offline   Reply With Quote
Old 05-19-2010, 09:05 PM   #2
glenn in camino
glenn in camino's Avatar
Default Re: Spark plug questions....
I run Champion 3Xs in my stock Model As.
glenn in camino is offline   Reply With Quote
Old 05-19-2010, 09:47 PM   #3
Bob A.
Originally Posted by Big Kevin View Post
Hi there.
Hey Kevin, I'm sure you know your going to need a plug adapter to run 14 mm. I did see a substitute chart running around here somewhere that tells which are best.
Bob A. is offline   Reply With Quote
Old 05-19-2010, 09:53 PM   #4
Jim Parker Toronto
Jim Parker Toronto's Avatar
On the old Fordbarn you could just go to the Tech Section, I think they were on Steve Plucks website. You need to check the heat range of the plug you want use. Some are hotter than others and may cause damage to your engine.
Jim Parker Toronto is offline   Reply With Quote
Old 05-19-2010, 10:08 PM   #5
J Franklin
J Franklin's Avatar
If you haven't run 3x plugs you won't have anything to compare for original running as Ford wanted.
J Franklin is online now   Reply With Quote
