Old 07-09-2018, 05:44 PM   #21
old31
Default Re: led light bulbs
Do I have the pricing correct? Seems expensive. $73.00 for 2 BA15S LED headlight bulbs.
Old 07-10-2018, 04:46 AM   #22
PRG999
old31. Yes you did the math correctly- I think it was 82.00 total to get it to the States.
I like them thou. Is it worth 82 bucks? who knows. They are brighter and give a nice white light, .
Just need to get the lights aimed correctly.
paul
PRG999 is offline   Reply With Quote
Old 07-10-2018, 10:40 AM   #23
Y-Blockhead
Y-Blockhead's Avatar
I use an LED in my dash light... Specs say: 96 Lumins of warm white light. But then again my system is 12v.
Old 07-10-2018, 10:56 AM   #24
briphaeton
Hi YBlock
What bulb number LED do you use for the dash light?
Thanks Brian
briphaeton is offline   Reply With Quote
Old 07-10-2018, 11:12 AM   #25
Badpuppy
Yeah, much greater variety in 12V.
Badpuppy is offline   Reply With Quote
Old 07-10-2018, 11:16 AM   #26
Badpuppy
paul
Looking at the construction of those bulbs, I wonder what the focus pattern looks like. -?
Old 07-10-2018, 11:37 AM   #27
Kurt in NJ
Kurt in NJ's Avatar
I saw one at Hershey, the focus pattern is sort of a figure 8 and fuzzy
The original bulbs have a V shaped filament, gives a sharp focused beam with clear edges without the lens at 20 feet just a little larger than the diameter of the light, the halogen bulbs I have use straight filaments, the focus is a little larger and some fuzzy edges--- so 1/32 makes a difference, the led bulbs move the light 1/8", and only 2 spots of light-- I think s lens could be designed to work with them, when led bulbs are OE the reflector is much different, sort of a cut in 1/2 rams horn
The real test is not how brilliant they look looking close, but how far the concentrated light is projected down the road---- most electric poles have reflectors, my car lights them up 8 poles away, about 1/3 mile--- 35 watt halogens, everything else original, including generator, never charged except by driving, I am going to try some hid bulbs, but for low beam it will have to tilt the bulb
Old 07-10-2018, 02:04 PM   #28
Y-Blockhead
Originally Posted by briphaeton View Post
Hi YBlock
Thanks Brian
I got it from Super Bright LED's. I'm pretty sure it was this one. https://www.superbrightleds.com/more...ofit-car/2077/ Check the base size because I bought it over three years ago. I'm not near my car or I would check.
Old 07-11-2018, 04:59 AM   #29
dumb person
dumb person's Avatar
Originally Posted by mfarley View Post
The LED replacement I'd really like to find would be for the dash light. I really want a solution that doesn't make the casting scorching hot when I try and turn it off.
The dash light? i forget what size that is but it doesn't look large.
Maybe adapt one of these?
https://www.aliexpress.com/6V-LED-Bulbs-P5W
Or solder this in an old broken bulb
https://www.aliexpress.com/-LED-Conversion-upgrade-Dashboard-bulb-5v-24V
Rated from 5 volt up to 24 in the same bulb huh?
Then this one looks like a straight swap for a headlight bulb, and doesn't need to be modified for focus.
https://www.aliexpress.com-6-1200LM
Seems to be a few options out there.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 07-11-2018, 12:57 PM   #30
Badpuppy
That one might do if soldered into a BA15S base, but voltage spec at 9-14V.
The only 6V BA15S offered by superbright these days is forward firing.
Maybe a 12V (AC/DC) @ 250 lumens or so would work. LEDs are usually dimmable.
Pays yer money, takes yer chances.
Old 07-11-2018, 03:17 PM   #31
Badpuppy
That one appears identical to the one from GB, down to the same number printed on it, except different size print. Half the price, guaranteed, but probably not pre-tested.
I'm still skeptical about the focus; Henry's reflectors just weren't designed for them.
Ya pays yer money, ya takes yer chances.
Old 07-11-2018, 08:44 PM   #32
Y-Blockhead
OK, the LED I used from Superbright fit the stock dash light with no modifications. So I guess I'm mistaken.
Badpuppy, do you know what base fits the stock dash light? I have a list of LEDs I bought but I am not sure which one I used. I thought it was the one I linked to above...
Old 07-12-2018, 10:07 AM   #33
Badpuppy
All stock sockets except headlights are BA15S. Headlights BA15D.
Old 07-12-2018, 12:45 PM   #34
DHZIEMAN
Originally Posted by machineman64 View Post
I am looking for comments good bad or otherwise on the direct replacement led bulbs for the model a headlight. they are available from:
[email protected]
Has anyone installed these, are you satisfied?
John,
There is a company in England, they need to know some particulars and when I last checked, 3 bulbs, two for installation, and one spare was around $128.00. There are some other threads on this subject, lots of good info. Also, these LED's as I understand it are very bright and will do great. But, they cannot do well with poor reflectors, The silver on your reflectors has to be up to snuff too! I do not recommend what I did, I replaced the reflectors with a sealed beam kit that hides behind the Model A lens and looks OEM, but, the current draw is high and if you have an original Model A Generator, you have to up the charge to around 15 amps if you do a lot of night driving, and if you up it and drive during the day a lot, you are boiling your battery with overcharge. I bit the bullet and installed a 6v pos ground alternator! But starting on this again, I would have done the LED's got my reflectors re silvered and been done with it with real bright lights!
DHZIEMAN is offline   Reply With Quote
Old 07-13-2018, 12:17 PM   #35
Badpuppy
The headlight specs on the aliexpress site show 930 lumens, roughly equivalent to 50+32 CP. Difference is that both LEDs light on high beam, so it's more like 80/40 CP. Obviously it throws a lot of light out there. However due to the thickness of the mounting, there's a significant dead band between the two LEDs, explaining the figure-8 pattern. I'm sure they will do for most folks, but Henry's rolling.
Old 09-29-2019, 08:02 PM   #36
Merc Cruzer
Merc Cruzer's Avatar
Octane Lighting
675 Cochran St. Simi Valley,
CA 93065
Toll Free (855) 962-8263
International: (818) 932-9522
Email: [email protected]
Open: 24hrs
As to LED positive ground bulbs:
https://www.ledlight.com/g18-s25-2_6...-polarity.aspx
Go into the web site, then click on automotive, then scroll down to 6 volt positive ground - three pages of bulbs.
Merc Cruzer is offline   Reply With Quote
