09-17-2018, 07:20 PM | #1 |
Skipping during acceleration when engine is warm
So I noticed this issue about a month ago when I was driving my 30 Tudor. When the engine is cold, it runs and accelerates with no issue. Once the engine warms up to operating temp, I have bucking and skipping during acceleration. I had a Zenith on the car, but am now running a Marvel with the same issues.
I have re-timed the engine, changed the oil, cleaned and set the points, re-gapped and cleaned the plugs, and cleaned out the whole fuel system. Any thoughts? |
09-17-2018, 09:41 PM | #2 |
Re: Skipping during acceleration when engine is warm
Try a new condenser on the distributor. They often act funny when hot but do OK when cold.
Report back.
09-17-2018, 09:47 PM | #3 |
09-17-2018, 10:15 PM | #4 |
Possible plug fowling.
09-17-2018, 11:12 PM | #5 |
Loosen the gas cap so that air can get inside the tank and then take the car for a drive. Problems arise with a plugged cap vent when the weather is hot - like now.
M. |
09-18-2018, 05:39 AM | #6 |
09-18-2018, 07:45 AM | #7 | |
Question on the (4) Jumper wires? Should it be two one to ground and the 2nd to the pass side of the coil? thanks,
Keith |
09-18-2018, 08:24 AM | #8 |
Every time I've thought a problem was fuel, it turned out to be ignition. Check everything in the ignition system you haven't already checked, you'll find the culprit.
09-18-2018, 10:18 AM | #9 |
You want to ground the cond. then go from center of cond to pass side of coil. Guess that’s just two jumpers.
