01-27-2022, 03:04 PM | #1 |
60HP vs 85HP transmissions
Will an 85HP transmission bolt up to a 60HP bellhousing and vice versa. I've either forgotten or never knew. I'm thinking the answer is NO. How wrong am I? LOL
01-27-2022, 03:15 PM | #2 | |
Re: 60HP vs 85HP transmissions
They WILL bolt-up! DD . Last edited by V8COOPMAN; 01-27-2022 at 03:21 PM. |
01-27-2022, 03:45 PM | #3 |
Thanks coopman, but they are not the same transmission are they? Clutch cross shafts are different length aren't they, at least per the Green book.
01-27-2022, 03:54 PM | #4 |
01-27-2022, 03:58 PM | #5 | |
They ARE NOT the same transmission, for sure. Look at the shift COVER...on the 60 HP, that cover is held-on by ONLY 4 bolts. The 85 horse transmissions have SIX (6) bolts holding the covers on. Back in the early '60s when I was YOUNG and "sarcastic as usual", I put a used 60 HP in my '39 that I had taken the 'blown-up' 85 horse engine out of. Bolted right up, starter cranked it and clutch worked as normal. DD . |
01-27-2022, 04:17 PM | #6 | |
01-27-2022, 05:34 PM | #7 |
I am having trouble posting a pic of Lawsons 60 and trans. His trans has the cast in bendix pocket on the bell and no other trans had that. 85/100 bendix was covered by a can in the rear of the oil pan.
01-27-2022, 07:34 PM | #8 | |
ALL V8-60 transmissions will have a serial number beginning with a "☆ 54-". DD . Last edited by V8COOPMAN; 01-27-2022 at 08:02 PM. |
01-27-2022, 08:10 PM | #9 |
Thats an interesting arrow in the vin number DD. I have seen just a straight -, and the common double single line arrow, but never a double triangle thing like that. Looks like the straight - was done first. A new one for me!
01-27-2022, 08:26 PM | #10 | |
Agreed....me too! DD . |
01-28-2022, 08:59 AM | #11 |
Lawson's engine apparently has the optional trans mentioned above with 85 gears and six bolts in the cap. His trans definitely has the bump for a starter bendix.
