Old 02-15-2014, 02:00 PM   #1
bartmcneill
bartmcneill's Avatar
Default 1937 ford coupe doors
I have heard that 37-40 front doors on a four door car will fit a 5 window coupe. Anyone know if this is true and what modifications must be made to the door to make it work?
bartmcneill is offline   Reply With Quote
Old 02-15-2014, 03:01 PM   #2
fordscript
fordscript's Avatar
Default Re: 1937 ford coupe doors
Yes they will fit, the difference is in the top rear corners. The coupe doors taper down to the rear, sedan doors continue straight along...
fordscript is offline   Reply With Quote
Old 02-15-2014, 05:39 PM   #3
bartmcneill
Thanks, I called the guy and found out he had the doors so I am good there. see it at www.picturetrail.com/bartmcneill if you want. Just got everything but the body and frame hauled home.
