08-20-2019, 08:12 PM | #1 |
interior handle sleeve nut fit?
1931 Murray fordor. I am wondering about the fit of the sleeve nut for the interior door handle. When I finished installing one it sat proud of the handle i s this correct? It does not look right to me I think flush or slightly inside the handle would look better. Original handles the sleeve nuts are new
Thanks |
08-20-2019, 08:42 PM | #2 |
Re: interior handle sleeve nut fit?
There might be a lock washer stuck inside the pocket of the handle.
If not, then I'd trim the inner edge for a flush fit. |
08-20-2019, 10:03 PM | #3 |
Post a photo, I think they are above the handle on mine. Maybe yours are correct. Are they or the handles reproduction?
08-21-2019, 08:32 PM | #4 |
[QUOTE=Tom Wesenberg;1790202]There might be a lock washer stuck inside the pocket of the handle.
If not, then I'd trim the inner edge for a flush fit.[/QUOT I tried with and without a lock washer and the nut is proud of the handle either way Thanks |
08-21-2019, 08:34 PM | #5 |
08-22-2019, 06:14 PM | #6 |
08-22-2019, 06:20 PM | #7 |
If someone can measure the length of a original nut I would appreciate it.
08-22-2019, 06:41 PM | #8 |
If you put the backside on a belt sander for a few minutes it will sit lower. It does look tall or your handle does not have enough depth. the handle could be a replacement. Maybe someone has an original apart for comparison. The original drawings can be found in Detroit I believe.
08-22-2019, 06:55 PM | #9 |
I don't know if this helps you or not. I just ran out and took a picture of my door handle. I believe they are both Repos (handle and nut). This is without the lock washer.
To tell the truth, I never paid much attention to them. Hopefully someone has an original we can look at. Last edited by Y-Blockhead; 08-22-2019 at 07:01 PM. |
08-23-2019, 08:32 PM | #10 |
Thanks for the picture
