04-02-2022, 12:31 PM | #1 |
Do I need a new Coil?
It's spring and I can't get the Bug going! Battery's charged, points and plugs, polished, fuel bulb cleaned, but I'm not getting any spark from the coil lead. Do I need a new one? I figured if that's not happening, I've got to start there. Any suggestions? Thanks everyone, in advance.
04-02-2022, 12:46 PM | #2 |
Re: Do I need a new Coil?
Have you check the voltage at both Coil posts?
Regards Bill |
04-02-2022, 02:34 PM | #3 |
To check the coil I set the points open, and with the key on bridge the points with a screwdriver. If the points are not working this will bypass the contacts.
04-02-2022, 03:20 PM | #4 |
What is voltage at open point arm ? Should be 6v
What is voltage at closed point arm ? Should be zero. If not, clean them. |
04-02-2022, 05:54 PM | #5 |
Check voltage on the point side of the coil. With points open, should be battery. Turn engine over by hand crank until points are closed, should now be 0v on point side of coil. If not, points need more cleaning/burnishing. DON'T start replacing parts. You'll just end up introducing problems.
04-02-2022, 05:59 PM | #6 |
04-02-2022, 07:29 PM | #7 |
That is a great diagram for the stock ignition system. If you have a 12 volt negative ground system with an aftermarket ignition switch, then it could be different, but the basic principles are the same.
04-02-2022, 07:38 PM | #8 |
Just a thought.. Do you have power at the points? If not, it could be the lead from the ignition switch to the distributor or a condenser gone bad..
04-02-2022, 08:59 PM | #9 |
If you do not already have it, purchase the Les Andrews Red Book. It goes through step by step what to check; what voltage you should have and where the voltage is. Check your point gap.
04-03-2022, 08:43 AM | #10 |
A multi-meter will allow a lot of checks on electrical components. Set to read Ohms, the coil can be checked between the two terminal posts for a reading very near 1.5-Ohms. If no reading the the coil is open somewhere in the winding and no good. If the reading is much higher, then it is either a 3-Ohm coil or it has damage internally that is causing high resistance. The secondary coil winding can also be checked. Only one of the two small terminals is connected to the secondary and the other end is connected to the tower high tension terminal. The secondary has very high resistance due to the high number of turns in its coil. Resistances vary with manufacturers but they would likely start around 8,000 to 12,000 ohms.
Back in the day, there were test sets for coils that powered them up for a period of time to warm the coil up. There was a breaker set built into the unit to provide a high tension spark during the test. If the test set gave serviceable indications then it was good to go. If a person has no test set then it has to be tested in the vehicle with a home made test rig. Some coils fail after they warm up due to a crack in the wire that grows with heat. This is the reason they warmed them up before testing. Last edited by rotorwrench; 04-03-2022 at 08:54 AM. |
04-03-2022, 11:56 AM | #11 |
Notice that nobody has suggested to automatically assume that no spark means to replace a part.
Coils don't go bad that often. There are several parts and adjustments in the path of no spark. It could be as simple as a blown fuse. Throwing new parts at solving a problem can be an expensive proposition. I wholeheartedly agree with getting a volt meter out and following the circuit. Good luck! |
04-03-2022, 12:50 PM | #12 |
I'm having the same issue. I 'fired up' Bessie (my '29 RPU) a few weeks ago, only to have it quit then not start again. Last summer I put in new points, condenser, plugs, cap, rotor, armored cable with new switch, new wires, etc. and had it running around the yard and up-n-down the road last fall before I put it away for the winter.
I thought I may have flooded it, but when checking the points for an arc w/a screwdriver....nothing. I started at the fuse, ignition switch, then ammeter....nothing. Before 'losing my mind', I walked away from it and thought about doing exactly what Bill G just said above. I will put it back together and use my voltmeter to chase the issue once it warms up around here. |
04-04-2022, 09:44 AM | #13 | |
04-04-2022, 10:15 AM | #14 |
I don't know what companies still manufacture the model A type condenser. A&L was making a good quality unit with modern materials that held up fairly well to the heat. I assume they are still available but less is certain in this day and age.
The modernized plate with late type Ford applicable condenser seems more common than it once was. I used to use the Echlin condensers but they are now owned by Standard Motor Parts. I've had my ups and downs with modern types and have purchased two or three at a time to insure I'd at least get one that would work properly. Many are bad right out of the box. Some will work but get unreliable at low rpm. When I get a good one, I run it till it starts to get flaky then try another one. Leaving the ignition switch on while points are closed will kill a coil so I always double check to make sure the pop out button is pushed in before I leave the car to set. |
04-07-2022, 06:29 PM | #15 |
Okay, thanks everyone. I repolished all contacts, trouble light was giving me 6 volts at each point, cranked it over a while and, finally, she fired up and started!! I guess she just needed a stern talking to . . . or perhaps the gas was a bit stale. Anyway, she's running, so thanks for the encouragement and happy motoring!!
04-08-2022, 07:31 AM | #16 |
Put a bottle of gas dryer/fuel injector cleaner in it.
04-08-2022, 08:15 AM | #17 | |
04-08-2022, 04:17 PM | #18 |
A lot of people screw the ignition cable to tight into the dizzy, loosen it up and then back just finger tight, can't hurt to try and only takes a minute
04-08-2022, 04:42 PM | #19 |
Had a similar issue a couple of weeks ago. My coupe would start then die after about 5 minutes, it acted like a bad condenser. Used my meter and found .3 volts at the points after it warmed up. My wire in my armored cable ended up being the culprit
