Old 08-31-2018, 08:30 PM   #1
nosoup4u
Default Are 3 and 4 speed trannies interchangeable?
What needs to be done to change a 3 to a 4?
nosoup4u is offline   Reply With Quote
Old 08-31-2018, 09:25 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Are 3 and 4 speed trannies interchangeable?
First of all, an AA four speed has nearly the same gear ratios in 2nd, 3rd and 4th (1:1 final) as the A three speed does in 1st , 2nd and 3rd (1:1 final).
What you gain with an AA four speed is a very low first gear...6.4:1 vs the A 3.12:1
The change requires a different, shorter clutch housing, to compensate for the longer AA 4 speed, and probably the toughest part to find is the special universal joint with 10 splines on the transmission end to 6 splines on the output/driveshaft end.
Info on the AA transmission change is here
http://www.fordgarage.com/pages/aafourspeedachassis.htm
And an earlier discussion here...
https://www.fordbarn.com/forum/showthread.php?t=167726
Now if you are talking a newer Ford 4-speed OD transmission, that is very different.....
There will be more responses!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is online now   Reply With Quote
Old 08-31-2018, 09:35 PM   #3
nosoup4u
The granny low is what I'm after. See my other thread Car goes too fast!
Old 08-31-2018, 09:42 PM   #4
1955cj5
1955cj5's Avatar
The AA will give you that for sure....you can easily walk faster than the car will go idling in first!
Perfect parade gear....!
