Old 06-09-2012, 09:41 PM   #1
mmindling
mmindling's Avatar
Default More about transmission fluid plus question
Hi, this is Martin in Ohio. Many thanks to all who made helpful suggestions
regarding the multi-disc clutch problems in my 1928 phaeton. Sprayed two cans of brake cleaner through the clutch and drained it. In the gear box, put in a mixture of Lucas Oil Stabilizer and Transmission Heavy Oil. With both changes made, took it out for a drive and found a marginal to good improvement in the clutch action and related improvement to the gear grinding problem. The drive was also fun, reckless on country roads.
Question: Does anyone know what plant is identified by the body number "M"? My car has a stamped number on the floor panel support which is
M*335. The M is very large (much larger than the numbers) and almost
appears to be stamped with a different kind of tool, while the star and 335 are clearly a single type of stamp tool. When did the M plant start production? Why the wierd anomoly in the stamped numbers? Could I be misreading the M instead of a real identifier? It is much more faint than
the numbers.
Thanks for the input,
Regards,
[email protected]
mmindling is offline   Reply With Quote
