08-27-2023, 04:03 PM | #1 |
Flathead engine storage
I just moved 3 complete flatheads to my new barn/shop with modified
H/F 1000# dollies. The dollies got there but the casters bend easily and they have all kinds of casters in their store except dollie replacements. My question is, what have you guys built to move/store your flatheads ??? I was thinking of welding up a frame that bolts to the exhaust ports. Figuring if one side of exhaust bolts can hold, then both sides together would easily work. |
08-27-2023, 04:15 PM | #2 |
Re: Flathead engine storage
Make a wood base that motor sits on .
Make sure no weight is on Oil Pan . Then put Wood Frame & Motor on a Cart |
08-27-2023, 08:40 PM | #3 |
Make a separate 4 wheel dolly for each engine , stand each vertically and bolt the belt housing of each engine to a dolly. This takes up less space.
08-27-2023, 09:07 PM | #4 |
08-27-2023, 09:39 PM | #5 | |
08-28-2023, 08:08 AM | #6 |
https://www.stumpysfabworks.com/stor..._Products.html |
08-28-2023, 04:35 PM | #7 |
I have a spare flathead bolted to a Stumpys fab works stand and I added 4 HD wheels from Harbor Freight. It rolls around my shed nicely.
08-28-2023, 05:56 PM | #8 |
STUMPYS FAB WORKS > https://www.stumpysfabworks.com/stor..._Products.html
FORD FLATHEAD 59AB/8BA Cradle $66.00 Ford Flathead 59AB/8BA, 85 - 100 HP V8 Cradle Comes with mounting hardware. Will support engine or engine transmission together .....$66.00
08-29-2023, 12:18 AM | #9 |
I build these double deckers from 40 dollar Harbor Freight engine stands. Of course I'm dealing with bare blocks so my design would need to be modified. So far no caster failures and they don't take much floor space. The lower blocks sit on their pan rails on 3"x 3/16" flat stock on edge. I weld a 3/8" dia pin sticking up an inch above these cross arms so the blocks can't slide off when taking a corner at high speed.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
08-29-2023, 12:20 AM | #10 | |
08-29-2023, 10:32 AM | #11 | |
08-29-2023, 01:13 PM | #12 | |
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
08-29-2023, 01:30 PM | #13 |
08-29-2023, 02:10 PM | #14 |
08-29-2023, 05:40 PM | #15 |
There’s a few more kicking around....There was just a thread on aluminum Canadian Merc manifolds.....Id like to find one those......Mark
