Old 12-18-2017, 09:42 AM   #1
chap52
chap52's Avatar
Default 5.5:1 or 6.1:1 High Compression Heads?
Working with a basically stock motor. Other than the obvious increase in horse power with a new high compression head, what are the pros and cons of the addition? Secondly 5.5 vs 6.1 pros and cons.
Just getting into these engines and would appreciate your in sites.
chap52 is offline   Reply With Quote
Old 12-18-2017, 10:25 AM   #2
Chevmn56
Chevmn56's Avatar
Default Re: 5.5:1 or 6.1:1 High Compression Heads?
Subscribed!!!
Chevmn56 is offline   Reply With Quote
Old 12-18-2017, 12:20 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
My personal opinion is you telling us that your engine is "basically stock" really does not tell us what we need to know to help you determine the best advice for you. If the babbitt bearing material in your 'basically stock' engine was incorrectly done, --or was poor quality babbitt, it will likely fail using either head. On the flip side, good quality babbitt work done on a 'basically stock' engine will last a long time with either of the heads you referenced, and also do equally well with heads that have a higher compression ratio too.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-18-2017, 01:27 PM   #4
2manycars
2manycars's Avatar
I have a 5.5 head on my tudor, with babbitt bearings, and it has done fine so far, at about 12,000 miles.
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 12-18-2017, 01:43 PM   #5
GPierce
GPierce's Avatar
Originally Posted by Jim Brierley View Post
It's not high compression that causes babbitt problems, it is detonation. I ran a 7.4:1 Cyclone head for years with no problems.
Yesterday we heard compression isn’t a problem with Babbitt?
GPierce is offline   Reply With Quote
Old 12-18-2017, 01:56 PM   #6
hardtimes
hardtimes's Avatar
Hm, so whom do you believe ?
If you know WHO posted that comment, you would be inclined to believe it. You could also ask him , about any reservations that you may have. He is a very helpful /very experienced / older member !
hardtimes is offline   Reply With Quote
Old 12-18-2017, 03:24 PM   #7
Ron in Quincy
Ron in Quincy's Avatar
I am partial to the 5.5 Snyder Head.
A high compression head would be the most notable change you could make.
It might be a good time to drop the pan and tune up the main and rod bearings, depending on the miles you have put on the engine.
Ron
Ron in Quincy is offline   Reply With Quote
Old 12-18-2017, 03:59 PM   #8
chap52
chap52's Avatar
This is all "brain picking" for me as I have not started the project yet.
Thanks to all.
Old 12-18-2017, 05:02 PM   #9
Bruce of MN
Bruce of MN's Avatar
My motor has insert mains, the stock cam, and a Tilly. I'm planning on getting a 6.0 head, but no other changes, at least not right away. Will the carb need any more than adjusting?
Bruce of MN is offline   Reply With Quote
Old 12-18-2017, 05:17 PM   #10
TerryH
TerryH's Avatar
I had a Snyder 5.5 head installed on my Town Sedan, shortly after I bought it about 11-12 years ago. Probably the single most effective power gain for the cost and ease of installation, and with prudent use of your spark control (not over advancing), should not be harmful to your bearings.....assuming you have good quality to begin with. I have over 12,000 miles on mine with no issues.
TerryH is offline   Reply With Quote
Old 12-18-2017, 05:53 PM   #11
chap52
chap52's Avatar
I am encouraged by the testimonies. I guess that I was wondering, if all else is is OK is it worth going with the 6.1 over the 5.5?
Old 12-18-2017, 06:22 PM   #12
duke36
5.5 is a good compromise and heed Terry's post #10.
duke36 is offline   Reply With Quote
Old 12-18-2017, 06:43 PM   #13
loubob
5.5:1 works well for me.
loubob is offline   Reply With Quote
Old 12-18-2017, 07:05 PM   #14
Karl
Karl's Avatar
On mine I have insert bearings and a 5.5 Synders.
Works fine and I drive mine a lot. It will cruise at 50mph for hours on end and I have over 15000 miles on the head with no problems. I don't find any increase in top end speed with the 5.5 Head. (about 60mph on the rare occasions I open it right out) but pick up is definitely better -Karl
Karl is offline   Reply With Quote
Old 12-18-2017, 07:56 PM   #15
CWPASADENA
CWPASADENA's Avatar
With a babbitt engine, I would only consider a 5.5 head. As previously stated, just watch the spark advance and do not lug the engine.
If the bearings are in good condition, with a little prudence in your driving technique, you should get very good service out of your engine.
You will really like the increase in compression, it really improves performance of the engine.
My opinion,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 12-19-2017, 08:28 AM   #16
chap52
chap52's Avatar
Thanks to all for the input.
Have a Blessed Christmas
Old 12-19-2017, 09:05 AM   #17
Terry, NJ
Terry, NJ's Avatar
When I was a pilot and wanting to buy my own plane, I had a discussion about power requirements. Many small plane manufacturers were not inclined to "overpower" their machines. The original Piper/Taylor Cubs when first built, were only 36HP. That's hardly enough to get a heavily loaded Cub out of ground effect. You have no reserve power to prevent a stall. Put-Put airplanes are widow makers. It's a similar case with a put put car. Take a stock A out on a interstate. In rush hour you'll get to know what real fear is. Some will argue that the A is not a "put put" automobile. I will argue that compared to a modern car, It is. My Transit has over three times the HP and the rush hour traffic on I-25 in Denver, this year, kinda scared the sweat out of me and I wish I had more. The most effective way to to boost the HP to more modern levels is a H.C. head. Being conservative myself and always conscious of the bearing load, I advise a 5 1/2-1, but even a 6-1 isn't even that high. My diesel Jetta was 19-1. Word to the wise, Watch your timing!
Terry, NJ is offline   Reply With Quote
Old 12-19-2017, 12:46 PM   #18
V4F
V4F's Avatar
my banger is a 7-1 lion3 head . inserts & full pressurized . daily driver with no problems
V4f
V4F is offline   Reply With Quote
Old 12-19-2017, 12:57 PM   #19
chap52
chap52's Avatar
Thanks Terry, I remember back in the 80's when I could afford to fly, and flying a Cessna 150 into a strong Southern Oregon headwind, speed indicating 70 kts, ground speed calculated at 10 kts. . That's how I feel about driving old cars on todays freeways.I cruise to enjoy the trip, not white knuckle through the whole thing.
As I said I am just gathering info right now and apparently the difference between the two HC heads is not much of a gain.
Old 12-19-2017, 01:59 PM   #20
Pete F
Pete F's Avatar
Just a couple of comments
Raising the compression ratio that little is not going to cause any problems or raise the horsepower that much.
I build Duesenberg and Cadillac engines with Babbitt bearings and I run them with 8.5:1 with no problems
Like one other person said it the detonation that takes out a Babbitt bearing or an insert bearing
So just get a good bearing person to do the work and hold the tolerance .
Terry Harkin did mine until he got sick now someone took over his business and they are doing good work now
Pete F is offline   Reply With Quote
