Old 06-02-2019, 04:44 PM   #1
biggieou
Default Coil question
Is a Model A coil the same as a 50 Merc's? Obviously both are 6v.
Sent from my SM-N920V using Tapatalk
1931 Model A Victoria
1950 Mercury 8
Member: MAFCA, MARC, Northern Ohio Model A Club
www.northernohiomodela.com
biggieou is offline   Reply With Quote
Old 06-29-2019, 07:05 PM   #2
frank d kirkstad
Default Re: Coil question
Years ago I used the coil of my dads 55 ford to get my 30 model A started.I had to give it right back the 55 was our family car at the time.
frank d kirkstad is offline   Reply With Quote
Old 06-29-2019, 07:10 PM   #3
frank d kirkstad
Years ago I used the coil off my Dads 55 ford to get my 30 model A started.I had to give it right back,the 55 was our family car at the time.
Old 06-30-2019, 12:54 AM   #4
FlatheadTed
FlatheadTed's Avatar
I am not Bubba ,but Some time coils have been changed over the years but I think you will find it will work quite happily, I have used VW ones on v8s ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-30-2019, 01:36 AM   #5
Tinker
Tinker's Avatar
It'll probably work okay, if its a good coil and If the resistance is correct. Early yblocks (54-62ish/6v voltage reducer inline to the coil) used 6v can coils and can be bought from local parts stores. Internal resistance is higher.
lot of maybes though... and the best thing about being wrong is you learn something.
Old 07-01-2019, 03:55 PM   #6
supereal
supereal's Avatar
Some round coils have a builtin resistor, and should not be used in a circuit that already has a resistor, or the output will be weak. New coils for the early four cylinder applications, B-12000 are available for $20 from C&G. All original coils are faukty due to deterioration of the internal insulation. We have been buying old coils at swap meets for years as cores to be sent to Skip Haney for a rebuild. If you need a whole new coil, he has them for most applications. Rebuild for $90 including shipping. His email is skiphaneyfl/@aol.com. Good guy, fine work.
supereal is offline   Reply With Quote
Old 07-01-2019, 05:49 PM   #7
rotorwrench
rotorwrench's Avatar
The old originals likely had dioxin oil or something equally nasty inside to act as an insulator. The modern reproductions are more likely to be made with the same internal construction and materials as any 1.5-Ohm primary cylindrical can type coil. The can type coils generally don't need a ballast on 6-volt as long as they are no more than 1.5-Ohm. The later type coils for early V8 engines do need a ballast due to the design of the coil core and the way the coil windings had to be arranged around it internally. When they went back to the can types in 1948/49 they didn't need to use a ballast.
