Old 05-03-2019, 02:48 PM   #1
Joe/Ct
Joe/Ct's Avatar
Question Grease Baffle
Started replacing rear brake shoes on our '28 roadster, std and e-brake, and noticed that I do NOT have a grease baffle (at least on the right rear). Is that a problem or did the early '28s not have them?
Joe/Ct
"The older I get, the better I was"
Joe/Ct is offline   Reply With Quote
Old 05-03-2019, 07:44 PM   #2
burner31
burner31's Avatar
Default Re: Grease Baffle
Yes they had them, cost about $15 for original or $5 for repops
Keith
Shawnee OK
'31 SW 160-B
Old 05-03-2019, 10:35 PM   #3
Steve Plucker
There were two types...Make sure you get the right ones for your car.
Pluck
Old 05-04-2019, 07:19 AM   #4
Benson
Benson's Avatar
There are two lengths of bolt/nut combinations like Steve P says.
Repros and second style use "shouldered" nuts and shorter bolts.
Original style with the "spacers" welded to plate use the LONGER bolts and different nuts from stamped metal plates.
Just order the correct bolts for the plates that you have or buy.
Old 05-07-2019, 05:27 PM   #5
Joe/Ct
Joe/Ct's Avatar
Post Re: Grease Baffle
Thanks guys for your responses....great info. Got grease baffles and finished the brake job today...with a little help from my friends.
(Darn, why are the rears sooooo much harder than the front????)
Joe/Ct
