04-29-2019, 06:27 PM | #1 |
Brake Shoe Arching LA/San Fernando Valley
I had my shoes relined by Valley Friction in North Hollywood. But due to Haz Mat laws they can't arch them. Is the anyone in the San Fernando Valley or Los Angeles area who has a arching grinder?
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
04-29-2019, 06:50 PM | #2 |
Re: Brake Shoe Arching LA/San Fernando Valley
If they measured for the correct linings / thickness then you shouldn't have to.
"Came too close to dying to stop living now!" |
04-29-2019, 07:03 PM | #3 |
These guys are good and did my work 40+ years ago. Delmers precision brake in Santa Monica. Maybe they could help you out.
04-29-2019, 08:17 PM | #4 |
I remember Delmer's from my days living in Santa Monica. It's hard to believe that they are still business 60 years later.
04-29-2019, 11:52 PM | #5 |
04-29-2019, 09:13 PM | #6 |
04-30-2019, 12:03 AM | #7 |
Are they still in business?
04-30-2019, 05:44 AM | #8 |
Lacy at the Early V8 Garage in West Covina 855 268 0325
04-30-2019, 07:15 AM | #9 |
04-30-2019, 12:00 PM | #10 |
I haven't heard of this shop. Thank you.
04-30-2019, 07:11 AM | #11 |
I just did mine myself using a table belt sander, I took them slowly down until the drum would fit over the shoes, then laid a piece of sandpaper in the drum and sanded the shoe by turning it back and forth until I had a smooth arced surface.
I had the same problem finding someone that offers the service, the brakes work fine. |
04-30-2019, 11:59 AM | #12 | |
04-30-2019, 08:19 PM | #13 |
04-30-2019, 08:22 PM | #14 |
the epa thinks you will die looking at dust from across the street
04-30-2019, 11:22 PM | #15 |
TrucParCo in Anaheim turned the drums and arced the shoes to match on my tonner. This was back in 2005. http://truckandautosupply.com/
05-01-2019, 05:43 AM | #16 |
I installed a set of Boling Brothers "Lincoln" brakes on the '46 last year, and was disappointed with the performance of the brakes. I pulled the drums after several hundred miles, and saw that the contact area of each shoe was only about 50-60% of the lining length. Old school brake shops are not easy to find to have the shoes arced, so like Sod Buster, I measured and sanded the high spots to get a better contact pattern. I was surprised at the variance in the thickness of the lining material, and they were certainly not arced to fit a 12" drum. So far, the brake effort has improved, but I will pull the drums again at a later date to see how successful my job was.
05-01-2019, 05:54 AM | #17 |
I forgot to include the second picture.
05-01-2019, 06:58 AM | #18 |
I just learned this trick. Get a drum that's maybe over .060" and have it turned. Whiz wheel the mounting face off so you just have a ring. You can use the ring to help you gauge contact with the shoes. Give you a could visual of what's going on with the brakes.
05-01-2019, 12:32 PM | #19 |
Sadly Delmers Precision Brakes phone is disconnected.
05-01-2019, 02:30 PM | #20 |
51Woodie's second photo.
