Old 02-15-2020, 11:17 AM   #1
Shelbycsx
Default Motor with no serial number
I take it this is a b motor. 5-24-48 stamped on head 4 bolt water pump, oil pan looks like an A pan doesn't look modified. Looks like an I stamped on the timing cover
Shelbycsx is offline   Reply With Quote
Old 02-15-2020, 11:31 AM   #2
Sunnybrook Farm
Sunnybrook Farm's Avatar
Default Re: Motor with no serial number
Yes it has the fuel pump opening covered up so it was used in an A or commercial setting for something that didn't need a fuel pump. So at least a 32 or later, the head could be from a variety of places I guess.
Sunnybrook Farm is offline   Reply With Quote
Old 02-15-2020, 11:42 AM   #3
abachman3
abachman3's Avatar
Looks like a 'B' motor, as it has the Fuel Pump casting in the block. The head could be a replacement and dated when it was made. The oil filler tube looks like Model A, as does the Oil Pan.
abachman3 is offline   Reply With Quote
Old 02-15-2020, 11:58 AM   #4
Bob C
The pan has the dimples to clear the B rod nuts.
The B engine number was stamped on the top of the flywheel housing.
Bob
Old 02-15-2020, 12:13 PM   #5
Jim Brierley
I thought possibly a diamond B but that is the worst looking diamond I have ever seen and see no date cast near the fuel pump boss, so not a diamond block. Your pan is also a B, with the rear part cut off, necessary when using an A bell housing.
Old 02-15-2020, 12:22 PM   #6
PC/SR
I do not know B's. For my education is the vertical filler tube normal?
PC/SR is offline   Reply With Quote
Old 02-15-2020, 03:10 PM   #7
Charlie Stephens
The oil filler tube on the Model B was in the same location as the oil filler tube on the Model A. A very few tubes used on the early Model B's were the same diameter as the model A but longer. Most of the Model B tubes were a larger diameter after they left the block. The hole in the block for the tubes was the same size for both Model A and Model B engines.
Charlie Stephens
Old 02-15-2020, 06:32 PM   #8
Joe K
Joe K's Avatar
Be interesting to know if this a counterweight crank engine. Also the pattern of that combustion chamber.
With the oil pump cover off, you might look in and get a peek at that crank.
Joe K
Shudda kept the horse.
Old 02-16-2020, 12:07 PM   #9
Bob Bidonde
Bob Bidonde's Avatar
The motors in my Coupe and Victoria are aftermarket Model "B," but it is unknown when my engines were cast, and by whom.
Bob Bidonde
Old 02-16-2020, 12:13 PM   #10
Jim Brierley
Bob, If yours are diamond blocks, there is a date-code in front of and above the fuel pump boss, sometimes hard to decipher.
