02-12-2022, 07:07 AM | #1 |
firewall holes
what is the best way to fill holes in a firewall safely. i have about a dozen small holes.
thanks dick |
02-12-2022, 07:18 AM | #2 |
Re: firewall holes
Most people weld them in and then do the body work as part of a restoration. If you are talking about a running car and the holes are small then Bondo, sandpaper, and paint might be the answer. This would be a temporary repair and the next time the car is apart a more permanent welded fix can be done.
To avoid drilling holes in the firewall, things, such as switches or junction boxes, can be attached with magnets. To avoid scratching the paint a soft piece of cloth can be put between the magnets and the firewall.
02-12-2022, 08:51 AM | #3 |
Re: firewall holes
If you just want a quick patch, I would use JB weld. It is stronger than bondo and can be sanded and painted
02-12-2022, 10:02 AM | #4 |
Re: firewall holes
I learned from an old DIY resto guy about cutting patches to fill holes. Really small holes can be plug welded with care and the correct use of filler rod. Holes from 3/8" on up should be patched by fabricating little round patches to fit and welding them in. I've used a copper backing plate to plug weld some but a patch just takes a little longer. A person has to get creative to hold a patch in the hole. I use some of these new high strength magnets and scraps of metal to hold things when tacking. A person needs a source for the correct gauge of cold rolled steel to make patches. I keep 18 US Standard gauge 1008 draw quality cold rolled steel around for fabrication.
02-12-2022, 01:16 PM | #5 |
Re: firewall holes
If you don’t want to weld them and you just want something to fill the holes I have used electrical box plugs. These are generally 1/2” and larger and I had some 3/8” and they look ok when painted and a lot better than holes.
02-12-2022, 11:43 PM | #6 |
Re: firewall holes
02-13-2022, 07:49 AM | #7 |
Re: firewall holes
A "friend" uses black duct tape.
02-13-2022, 09:47 AM | #8 |
Re: firewall holes
The best way is to use steel plugs filed to fit and welded. I have used flat washers and then wafers from screws and bolts to put into the holes in the washer and then weld them in. I felt I really got into the hobby when I got a mig welder. Then grind them flat. In my early days of the hobby, I used fiber glass on the inside and then bondo on the outside, sanded smooth. In my latest restoration I installed a heat insulator on the inside of the car. All the welding uglyness disappears. This was standard in 1932 but there are reproductions that fit the Model A. Ed
