11-07-2014, 10:56 PM | #41 |
Re: School me on clutches.
Thanks bill. Like the way you talk... No I haven't done a run out on it yet , but that's should be done as one of my next jobs. My daughter will have to read it as I crank up front .. I can hear the moaning now! I'll have a real good look for cracks, but I don't think so.
I am about to go strip the gearbox but I doubt there is much to save.. It had me thinking that if the parts really add up I could just about buy the flat attack conversion to fit a Toyota 4 speed auto...mmm? Oh and I have got Macs book, be lost without that. Mart, it's a good point your making. the rake is not too bad, when I pulled the torque tube a bit of oil came out, seemed a normal amount to me . When doing regular oil checks really not much out of both, mainly due to the leaks they have.
11-08-2014, 06:08 PM | #42 | |
Synco. rings.. get new... also check the second gear for wabble ?? it should not. that's what kicks it out of second gear. at times ?? replace the bushing in second gear..its a press out/in thing... would like to see the cluster when you get it out ?? and a tooth count ? P.S. use Mac's for reference, but order parts from Van Pelt....he's a barner, and one of us..........OLD.....BILL |
11-08-2014, 10:35 PM | #43 |
Just about nothing is salvageable . Only the shifter tower is good..the best part was the cluster and that has broken teeth, I found two end plates and I'm not sure if the wire ring is even a part? Have a look at the end of the shaft looks like it's been dropped? I had to bash the synchro hub off.. The 4 speed auto is looking better by the minute... Now to check the flywheel..
11-08-2014, 10:37 PM | #44 |
Another pic
11-09-2014, 12:15 AM | #45 |
Just checked the runout on the flywheel . Checked 5 different spots the very most was .004 good average two and a half thou' .. So what's allowable?
11-09-2014, 09:57 AM | #46 |
Martin. |
11-09-2014, 08:17 PM | #47 |
Thanks Martin..
11-17-2014, 12:49 PM | #48 |
