Old 08-09-2020, 04:35 PM   #1
hoffernsp
hoffernsp's Avatar
Default 51 Merc hand brake cable
All parts ready to reinstall. Any tips/tricks to get the snake/spring cable back on to the parking brake lever? Backed off the cable to the max but still having problems compressing the spring to connect the cable block end onto the lever. I maybe should have left the lever hooked up to the cable and then removed the lever from the shoe?? Anyone experienced with this?
My knuckles and fingers are paying the price.
Thanks
hoffer
hoffernsp is offline   Reply With Quote
Old 08-09-2020, 05:19 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: 51 Merc hand brake cable
If the cable is tight all the way to the hand lever you may be able to pick up an inch or so by releasing the hand lever and moving it forward.
Old 08-10-2020, 04:51 AM   #3
richard crow
are you talkiing about attaching the cable to the rear brake shoe levers if yes there is a simple way to do this
richard crow is offline   Reply With Quote
Old 08-10-2020, 11:17 AM   #4
hoffernsp
hoffernsp's Avatar
Yes I can't get the spring retracted enough away from the "end plug" to set the cable back onto the parking lever. Any tip is appreciated.
thanks
Old 08-10-2020, 11:19 AM   #5
hoffernsp
hoffernsp's Avatar
Also I backed the cable off the yoke to get more slack but that didn't help much.
Old 08-11-2020, 05:54 AM   #6
richard crow
take a pair of plyers now hold the swedge .then take a pair of side cuing plyers put the jaws between the swedge & the spring .now push the spring back then squez the side curing plyers enought to hold the spring install cable on lever release side cuters hope you can under stand this even with miss spled words these instrustion will work
Old 08-14-2020, 08:05 AM   #7
hoffernsp
hoffernsp's Avatar
Thanks worked as you suggested. The only issue I had was trying to hold the Swede and a needle nose vice grip to old back the spring and trying to hook the cable unto the lever. It helped to have the wife hold the Swede while I held the spring and hooked the cable. Too much for one person to hold all three.
thanks
