08-07-2015, 05:57 PM | #1 |
239 OHV vs flathead
Does the 1954 239 OHV share any parts with the 8BA flathead?
08-07-2015, 06:03 PM | #2 |
Re: 239 OHV vs flathead
Not even the bore and stroke. DD
08-07-2015, 06:22 PM | #3 |
Pilot bearing. Sparkplugs. I think maybe the points and condenser
08-07-2015, 06:25 PM | #4 |
I hope your not trying to get parts for that engine. There scarser than hens teeth. That's one year only 1954, Walt
08-07-2015, 07:52 PM | #5 |
Performance wise its rhe lamest of the y block motors.
08-07-2015, 08:52 PM | #6 |
08-07-2015, 09:04 PM | #7 |
I gave away a 54 yblock just last year. Not the best of the yblocks. Lot of odd ball little things. Some can be converted to later stuff though. I'm 99 percent sure the intake manifold is a one year thing, making it a 2 barrel deal. Or maybe a sling shot adaptation. But not 100 percent on the intake.
08-07-2015, 09:06 PM | #8 |
Had a '54 ohv. Did not like that car or its engine. My experience was that the engine performance was void of any spirit and it had troubles with valve train. The later 289 was a winner .... put a 1965 in my 17 foot ski boat and it really hustled .... still runs too.
08-07-2015, 09:08 PM | #9 |
Intakes had smaller ports. Edelbrock even made a small port Intake for them. There was a factory 1954 castiron small port 4 barrel used a teapot carb like the 55/56:
08-07-2015, 09:13 PM | #10 |
Thanks skids for the education.
08-07-2015, 09:15 PM | #11 |
Will the later intakes bolt to the 54?
08-07-2015, 09:41 PM | #12 |
Physically they will bolt up but I going to say no because there is serious port mismatch in the later intakes because of the bigger port size on the later intakes. Some have done it successfully but it really is a hit and miss operation.
The only four bbl manifold that works is the 54 Merc. Pretty rare now a days.
08-07-2015, 09:47 PM | #13 |
I suposse you could do some port grinding but you'd just be putting hard work into a pointless endeavor. Maybe.
. Last edited by Tinker; 08-07-2015 at 10:03 PM. Reason: Clarify a sentence |
08-07-2015, 10:00 PM | #14 |
I had a stock, original 239 in a f-100. It ws so sorry, and tired, it would not pull high gear, if any extended grade, however slight, was encountered.
