01-26-2019, 08:05 PM | #41 |
Re: Removing a snap ring
cutoff wheel is your friend.
01-26-2019, 10:09 PM | #42 |
i dont recall taking one apart that is as stuck as yours, but i believe the back gear, first gear must slide on the splines to get the bearing completely into the case for removing the main shaft assembly. if your bearing has stopped moving, check to see if that back gear is hitting something to stop all movement. you may have to get that gear loose too
01-27-2019, 12:37 PM | #43 |
The main shaft is frozen as one peace. I'd like to remove the 7046 small snap ring and see what comes out.
01-27-2019, 01:24 PM | #44 |
7046?
01-27-2019, 02:22 PM | #45 |
sorry; 7064. Small ring on the front shaft
