Old 01-04-2018, 07:20 AM   #1
kajnhedge
Default kajnhedge
Does anyone know what the length of the drive shaft should be on a 47 Columbia 2 speed rear end when putting it in a 28 roadster pickup?
kajnhedge is offline   Reply With Quote
Old 01-04-2018, 07:26 AM   #2
Mart
Mart's Avatar
Default Re: kajnhedge
Hello. Welcome to the Barn. It would be impossible to say, as this is a non standard application. If someone suggested a length that worked for them, it may not suit your rpu.
You'd do better to first of all work out how much you need to shorten the torque tube by, then shorten the drive shaft by the same amount.
Good luck with it.
Mart.
Old 01-04-2018, 08:47 AM   #3
Ray in La Mesa
I have '28 roadster pickup with a '46-'48 Columbia in it. It had been cut to fit the "A" back in the '60's. In the '70's I decided to lengthen the bed to put a camper on so I could drive it Alaska. Got married & flew instead of driving. Long story -- short, I reinstalled a stock '48 tube & shaft to determine my wheel base. I have the shortened shaft somewhere in my pile of rust so will try to find it & let you know.
Ray in La Mesa is offline   Reply With Quote
Old 01-04-2018, 11:46 AM   #4
Bob C
Are we to assume you have a stock engine and transmission??
Bob
Old 01-04-2018, 11:54 AM   #5
rotorwrench
rotorwrench's Avatar
Are you planning to put spring hangers on the axle bells? Using a later torque tube will require shortening it too. You might consider a Mitchel but I don't know if they make a drive shaft for the model A since it includes the pinion.
If this is an AV8 then everything from the placement of the motor mounts & drive train choices plus the suspension choices have to be considered. If you ask for dimensions on this then you have to copy everything from the car the dimensions came from.
