06-21-2019, 11:10 AM | #1 |
1914 Model T Gas Tank Shutoff Valve
I have lived with the brass, factory original shutoff valve that came with the car since I purchased it in 2006. It doesn't drip but it is always moist. I dismantled it a few years back and cleaned it and lapped the seats but it didn't help much. Now that the garage has a new, permanent scent, I want to change this valve to a more modern reliable design. Can anyone recommend a new shutoff valve that has been proven to be very reliable? Where can it be purchased? Thanks for your help, Ed
06-22-2019, 09:47 AM | #2 |
Re: 1914 Model T Gas Tank Shutoff Valve
Most tractor supply houses can provide a glass bowl type sediment bulb with a fuel shut-off and 1/2" pipe thread.
06-22-2019, 10:37 AM | #3 |
06-22-2019, 07:38 PM | #4 |
Nothing is safe including the fact you are sitting over the gas tank or using copper tube that use farrow type connections that can fracture and burst.
I have run one and am sure others have too. It is pretty protected up there.
I know the voices aren't real but damn they have some good ideas! |
06-23-2019, 07:53 AM | #5 |
Thank you for your answers. I like the idea of getting the original style valve if it has been updated with a modern soft seat. Does Langs have these valves? Ed
06-23-2019, 08:40 AM | #6 |
for this valve anyhow most have a shut off valve at the carburetor. But if you insist, I think you should re-lap again. Fine valve grinding compound down to tooth paste..then a pressure test with shop air on the bench. |
07-04-2019, 01:23 PM | #7 |
Take heed from Big Job !
07-04-2019, 09:47 PM | #8 |
There are other places that could show dampness. The thread into the tank, sediment bowl thread or even where the fitting (Bung) is riveted and soldered to the tank.
