03-08-2019, 11:28 PM | #1 |
8BA distributor adjustment
The distributor on our rebuilt 8BA is a NOS Ford. I recently read a thread that mentioned lubing the cam so I need to do that and plan on using lubriplate in the morning. I figured since it was NOS, I didn’t need to mess with adjusting it, but read in the manual tonight it still should be checked. What is the best tension scale to use for adjusting the spring tension?
Also when I was installing it, I put a little 3in1 oil on the springs but also the points which I think is a no no. How should I clean the points face of residual oil? JB |
03-09-2019, 05:54 AM | #2 |
Re: 8BA distributor adjustment
Spray a dollar bill ( finest emery cloth out there) with brake clean or laquer thinner and run between the contacts. Be carefull using lubriplate as its pretty thin. Suggest using a dab of wheel bearing grease.... |
03-09-2019, 09:30 AM | #3 |
For lubricating the cam and rubbing block, use only the grease specifically made for that purpose. It is formulated not to soften and run off at high temperatures and to adhere to the cam and not get spun off.
Those who do not move do not die, but are they not already dead? |
03-09-2019, 11:05 AM | #4 |
Amazon has cam lube. https://www.amazon.com/Standard-Moto...SIN=B000JKDAR6
03-10-2019, 01:05 PM | #5 |
Mac has the specs for that on this web page. http://www.vanpeltsales.com/FH_web/f...53_239-255.htm |
