Old 05-17-2021, 11:10 PM   #1
panhead_pete
panhead_pete's Avatar
Default My 1st Model A (non Hotrod)
Hi all
After owning a few hotrodded model A's Im about to purchase my 1st close to stock one, a 30 Coupe. To be honest am kind of excited about that!
Now Im in Japan and the car will be shipped to me and at the same time would like to bring across maintenance items etc as sourcing them here is difficult. Having never owned a stocker, plan is to keep it mostly that way although it already has 36 16" wheels and a few other subtle changes. That being said what would be some good service items to pick up? Also interested in maintenance books etc to guide me.
Any and all other advice would be greatly appreciated.
Thanks
Pete
Looking for an unrestored 33 34 3W or 5W coupe.
Thanks
panhead_pete is offline   Reply With Quote
Old 05-18-2021, 04:16 AM   #2
shew01
shew01's Avatar
Default Re: My 1st Model A (non Hotrod)
https://www.mafca.com/cart/index.php?productID=166
https://www.mafca.com/cart/index.php?productID=167
https://www.mafca.com/cart/index.php?productID=168
Old 05-18-2021, 07:57 AM   #3
Pat/Ohio
Pat/Ohio's Avatar
Nice '30 Coupe Pete! Your wheels are actually '35 Ford wheels.
Pat
Pat/Ohio is offline   Reply With Quote
Old 05-18-2021, 12:44 PM   #4
burner31
burner31's Avatar
They are going to freak seeing that driving around in Japan, keep a good eye on it.
Keith
Shawnee OK
'31 SW 160-B
Old 05-18-2021, 01:30 PM   #5
KGBnut
KGBnut's Avatar
It is a little hard to say without knowing the car and how it is equipped and/or modified.
I would get basic tune-up parts (points, condenser, plugs), but you would need to know if it has original points or "modern" points, or potentially converted to electronic ignition.
Spares I like to keep handy.... carburetor, starter, generator. I have an extra of each that I picked up at shows and reconditioned and tested. Some guys carry a spare distributor. That may be a bit much to start with. Around here they are easy to pick up at shows.
What do you know about the seller? Can you ask them about spares that they kept around? What are the condition/age of the tires? How many miles are on the clutch? What oil do they use?
They are really not high maintenance cars, but you may have to have spares shipped all the way from the states. I don't know if they had much of a presence in Japan. They were pretty common in Australia, and those were right-hand drive.
Regardless, good luck,
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 05-19-2021, 12:44 AM   #6
Brad in Germany
Brad in Germany's Avatar
......and a parts book in Japanese, like this one, might also be helpful
Brad in Maryland
Brad in Germany is offline   Reply With Quote
Old 05-19-2021, 02:54 AM   #7
updraught
updraught's Avatar
It would be good to have someone look at it and tell you what is needed.
Starting with the brakes, if the drums haven't been replaced it might be a good idea to get a new set already mounted on hubs with linings etc. to ship with the car. These are heavy items that need to go by sea. Sending them later by air will most likely be prohibitive.
updraught is offline   Reply With Quote
Old 05-19-2021, 07:33 AM   #8
panhead_pete
Thanks all. Really appreciate the help!
You are right about that Ken and Burner31, it is VERY unusual to see cars like these where I live. In 6 years here I've only seen a couple rods come through.
Cheers Pat for the correction on the wheels. I must have remembered that wrong.
Brad that book looks awesome, sadly I couldnt read it but my wife can
Updraught Im buying the car from a Ford Barn member and sounds like its been well maintained. Had a nice chat with him this evening and Im confident its been sorted out but I do like the idea of an extra set of linings etc, cheers.
Ken thanks for the detailed respsonse besides the wheels its fitted with a T170, 12v alt, model B distributor, cam and carb and possibly a head but need to confirm that. So your suggestion of points condensor and plugs is a great idea. Having not owned a banger before any suggestions for good suppliers of those?
Once again thanks for you help gents, never though I would get so excited about a fairly stock A
Thanks
Old 05-19-2021, 01:21 PM   #9
Brad in Germany
If you would like to learn more about the Ford Model A assembly plant in Yokohama, Japan, the US National Archieves has a video showing their entire Model A assembly process.
Here is the link to that video: https://catalog.archives.gov/id/91834
Brad in Maryland
Old 05-19-2021, 05:42 PM   #10
panhead_pete
Wow Brad thanks so much for that link!
Thanks
Old 05-19-2021, 08:22 PM   #11
Brad in Germany
If you ever visit Tokyo, in the Edo-Tokyo Museum there, on display (Section T6 - Modern Tokyo), is a 1930 Fordor which was used as a taxi in Japan.
Here is a photo of that car on display in the Edo-Tokyo Museum:
It was supposedly assembled in Yokohama (note its right hand drive and no fender lights).
Brad in Maryland
Old 05-20-2021, 08:19 AM   #12
panhead_pete
Thanks Brad! Have been to that museum a LONG time ago. Will have to revisit it.
Thanks
Old 05-20-2021, 05:48 PM   #13
1930artdeco
1930artdeco's Avatar
Great looking car and welcome to the club. Here is my two cents worth. It sounds like it is coming over in a container. Get back up alt/gen/starter/head/radiator anything you may want that is heavy shipped with it. Otherwise it will kill you to ship it later. As long as it is solid, then it should just be the small stuff you will need and any supplier will have that and be able to ship.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 05-21-2021, 08:31 AM   #14
panhead_pete
Thanks Mike, some great ideas there!
Which will be the best service manual/s for me to pick up?
Thanks
Old 05-21-2021, 10:51 AM   #15
Garwood
Garwood's Avatar
Great looking coupe. A little surprised you didn't try to find one in England or Australia for a right hand drive.
Garwood is offline   Reply With Quote
Old 05-21-2021, 05:31 PM   #16
mercman from oz
mercman from oz's Avatar
Congratulations Pete, that is a nice looking 1930 Ford Model A Coupe.
Old 05-21-2021, 07:42 PM   #17
panhead_pete
Thanks, stoked on it to say the least.
Had thought about that and had actually tried to buy a 33 off a mate in Aus but that didnt work out. As it is I have another coupe and a panhead coming as well so they'll all go in the one container.
Thanks
Old 05-22-2021, 05:47 AM   #18
shew01
shew01's Avatar
See post #2 for links.
Old 05-23-2021, 07:59 AM   #19
panhead_pete
Sorry Shew forgot to thank you earlier and forgot you posted the links. Will order these.
Thanks
Old 05-23-2021, 08:18 AM   #20
shew01
shew01's Avatar
No problem. I thought you might have missed the links that were mixed in with the other responses. I hope you really enjoy your car. My car has been a blast! :-)
