Old 02-24-2012, 07:16 PM   #1
Hunter
Default Radiator Splash Shield Felt Pad
As I was getting ready to install the radiator splash shield on my May 1929 coupe I noticed the four small holes at the top and by looking through the vendors catalogues figured out that felt pads were attached using these four holes.
On original cars were split rivets used to attach them?
What color were the rivets?
Which way were the rivets oriented? That is did the legs of the split rivets open against the felt? Or were the heads of the rivets in the felt and the legs opened up against the splash apron?
Thanks you - Hunter
Hunter is offline   Reply With Quote
Old 02-24-2012, 07:35 PM   #2
d.j. moordigian
d.j. moordigian's Avatar
Default Re: Radiator Splash Shield Felt Pad
Hunter,
The 28 that I have here at work has the rivet head towards the front(on the felt),
and is semi tubular style....Brazier head.
BTW..my shield looks unmolested.
Dudley
d.j. moordigian is offline   Reply With Quote
Old 02-24-2012, 08:51 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
My original is the same as Dudley just explained. I posted a picture of it last summer and will find it to post again.
Old 02-24-2012, 10:06 PM   #4
Hunter
d.j. and Tom,
Thanks for the quick reply. Tom a picture would be great.
Hunter
Old 02-24-2012, 10:36 PM   #5
Tom Wesenberg
This isn't a good picture but was intended for the guy who asked where the holes should be drilled in his repro part.
Old 02-25-2012, 01:18 PM   #6
Hunter
Thanks for the picture Tom!!
Old 02-25-2012, 07:29 PM   #7
Marco Tahtaras
Marco Tahtaras's Avatar
The original rivets used in 1928-29 were the same rivets as used for the hood bumpers and leather corners.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 02-26-2012, 09:47 AM   #8
Hunter
Thank you Marco!
Old 10-09-2017, 04:45 PM   #9
ahirt
Tom, could you post that picture again. My splash shield for my 28 Tudor has no holes and I am trying to figure out where to mount the felt pads. May be a repo. My understanding is that all the radiator splash shields had the pads.
ahirt is offline   Reply With Quote
Old 10-09-2017, 05:13 PM   #10
Dan Partain
Dan Partain's Avatar
Here are a few photos of an original.
-DAN
File Type: jpg Radiator splash apron 01 (800x598).jpg (349.2 KB, 131 views)
File Type: jpg Radiator splash apron 04 (800x598).jpg (329.9 KB, 126 views)
File Type: jpg Radiator splash apron 05 (800x598).jpg (282.2 KB, 111 views)
Dan Partain is offline   Reply With Quote
Old 10-09-2017, 05:38 PM   #11
ahirt
Perfect! Thank you much.
Old 10-09-2017, 05:39 PM   #12
ahirt
Thank you. Just what I need!
