Old 12-15-2019, 01:39 PM   #1
tinman7
tinman7's Avatar
Default Horn
Hi all, How do I wire a magnito horn for a 1917 Tourin and how does it mount on the fire wall? Horn button sits on the top of steering column.
Thanks
tinman7 is offline   Reply With Quote
Old 12-15-2019, 10:26 PM   #2
stevests
stevests's Avatar
Default Re: Horn
The correct bracket is available that one hole mounts to one of the steering column bolts - some mag. horns have 2 terminal & some 1 - I have a wiring diagram in the shop but you could probably find the wiring diagram on-line.
stevests is offline   Reply With Quote
