Old 01-10-2018, 12:54 PM   #1
robw
robw's Avatar
Default advice
I've got a 29 roadster pickup.
I'm afraid I screwed up and forgot to winterize the thing. Yes, I'm an idiot.
We've had below freezing temps here for the last two weeks.
I realized my mistake on the first day we had temps above freezing.
I put a kerosene heater in the garage and have kept the temps above freezing for the last 24 hours.
I opened the drain and a small dribble of water came out... hardly anything.
No water in the oil yet that I can see. No obvious damage anywhere.
Any advice on how to inspect this engine once I get it all thawed out?
I haven't driven the car since before last April, so it could be that the cooling system was mostly dry.
I figure if I keep it above freezing for another 24 hours then it should be thawed out...
What a stupid thing to do.
rob
robw is offline   Reply With Quote
Old 01-10-2018, 01:01 PM   #2
SeaSlugs
SeaSlugs's Avatar
Default Re: advice
Well get it 100% thawed out, pull the dipstick and check for water in there or high oil level. Might be a good bet to drain the oil into a clean pan and see how much water if any comes out.
If it seems OK id pull the plugs and do a leak down test - that will show the condition of the cyl and if any cracks/leaks developed into the water jacket.
If that checks good, id fill radiator with warm water and see where or if it comes out. Fill it up to the very top of the radiator neck, give the car a wiggle to burp any possible air bubbles out and top it off, let it sit for a few days and check the level again. Should stay filled (or very close due to slight evaporation)
If it does you may have to just run the car and get it up to temp to see if anything adverse happens. Monitor water levels very closely for awhile and monitor oil level/color.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-10-2018, 01:03 PM   #3
TinCup
TinCup's Avatar
Default Re: advice
The head is usually the first victim in a freeze. The tunnel to the water pump is the first place to look. Other than that if it did freeze it could have cracked the deck, cracked the water jacket, unfortunately any number of places. If the car was dry no coolant then you have a chance that no serious damage was done. Antifreeze is a wonderful thing and I have never understood those that run only water in their A.
TinCup is offline   Reply With Quote
Old 01-10-2018, 01:05 PM   #4
SeaSlugs
SeaSlugs's Avatar
Default Re: advice
also can crack the no4 piston water jacket thats hard to see against the firewall (fixable with JB weld). it can crack into the valve galley as well.
Old 01-10-2018, 01:06 PM   #5
WHN
Default Re: advice
We’ll keep our fingers crossed for you and your engine and radiator.
If it was full of “water only”, given the temperatures over the last few weeks, you very well could have a major problem.
Tell us how things work out. Again, I hope everything works out. Enjoy.
Old 01-10-2018, 01:59 PM   #6
Jacksonlll
Jacksonlll's Avatar
Default Re: advice
With a warm garage, fill it with water and see if it stays in there. If it does, start it up and run it for a while and watch the water. If all goes well, drain out a gallon of the water and put in a gallon of prestone concentrate to get it to a 50-50 mix. I bet you are ok.
Old 01-10-2018, 05:53 PM   #7
Mikeinnj
Mikeinnj's Avatar
Default Re: advice
Make that "add 1 1/2 gallons for a 50/50 antifreeze solution' as the Model A holds THREE GALLONS of coolant.
Mikeinnj is offline   Reply With Quote
Old 01-10-2018, 02:01 PM   #8
hardtimes
hardtimes's Avatar
Default Re: advice
rob
Hey Rob,
Silver lining here, may be that you had it parked in a shed when you realized may be a problem and took action.
And, as you indicate, if you've had a leaking problem, this may to the only case ....where a leak is/was GOOD . Let's hope that is the case.
In the current situation, I'd take a bucket of warm water (as your evidence shows 'no water in crankcase') and pour the warm water into the engine/radiator. IF it goes in ok...all may be well. IF it goes in partially and will not accept much, then ice may still be there...but the warm water will help dissipate /melt any ice. I think that you are lucky and have done the correct things now i.e.- heater, etc..
But, as you well know now , drain the system completely for storage. Ask me how I know. I lived in Pa, in former life and as a kid , learned such the hard way.
Old 01-10-2018, 02:09 PM   #9
JDupuis
JDupuis's Avatar
Default Re: advice
It happens...keep us informed of your findings. Jeff
Let's let pylons, be pylons!
JDupuis is offline   Reply With Quote
Old 01-10-2018, 02:53 PM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: advice
Being in a garage, "might" be of some help??? We're ROOTING for you, that everything is OK! The Dog has his TOES Crossed--LOL
Bill W, & Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 01-10-2018, 04:23 PM   #11
WHN
Default Re: advice
I believe water continues to expand until it reaches -238 degrees. If I am correct, the colder your motor has gotten, the more of a chance for damage caused by freezing. 30 degrees might not crack anything, where 0 degrees could.
I hope everything works out for you. Enjoy.
Old 01-10-2018, 06:56 PM   #12
1931 flamingo
1931 flamingo's Avatar
Default Re: advice
Open the drain petcock on the lower pipe, stick something into it in case there's sediment there and see if it drains. Drain it and forget about it until spring. If you want to be sure pull the lower hose(s) off. FWIW
Paul in CT
Old 01-10-2018, 07:11 PM   #13
Big hammer
Default Re: advice
Paul in CT
Paul beat me to it, the drain clogs! Fingers crossed!
get a bigger hammer tap done
Old 01-10-2018, 07:33 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: advice
I bought my 28 Phaeton cheap because the owner only used water, and in September in Minnesota the engine froze and cracked the head, even though the car was inside the garage. Sometimes it's nice that people only use water. LOL
Luckily the numbers matching block was OK, even though the head had a large 5" crack. Several have fixed cracks successfully with JB Weld.
Old 01-10-2018, 07:45 PM   #15
robw
robw's Avatar
Default Re: advice
Yeah, last spring I had a leaky radiator and had put water in it while checking out the repair. Then, of course life got in the way and I forgot all about it.
After a day and a half of a nice warm garage all that has come out is about a Dixie cup worth. I'm fairly certain the drain is not plugged, But I'll check and be sure.
Tomorrow I'll put some warm water in it and see how much it holds... and then promptly replace it with antifreeze.
Thanks for all the advice.
Rob
Old 01-10-2018, 08:07 PM   #16
davehc
davehc's Avatar
Default Re: advice
I would make sure I had some type of heat on it 24 hr's a day till I got that water out . heat lamps , torpedo heater , anything I could direct the heat to the engine and radiator with to get water running . Maybe even put a tarp over the engine area to help confin the heat till its done what you want to do . If you get the water out , defenitly refill with at least the premix stuff . As said before , keep us posted , and good luck.
davehc is offline   Reply With Quote
Old 01-11-2018, 01:18 AM   #17
Russ/40
Russ/40's Avatar
Default Re: advice
A few beat me to it, but don't panic yet, open the petcock and run a heavy wire like a coat hanger through it. Might just be some rust settled there.
Old 01-11-2018, 02:14 AM   #18
BillCNC
BillCNC's Avatar
Default Re: advice
Fingers Crossed,
Wrap an electric blanket around the motor as they can be had pretty cheap and really doesn't cost much to run. It will make sure that motor thaws out quickly and stays that way until you figure it out.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 01-11-2018, 11:12 AM   #19
BILL WILLIAMSON
Default Re: advice
We used to get Used Cars in on an Auto Transport, with a SCREECHING Fan Belt, from a frozen Water Pump, even!!
We'd remove the radiator cap, SNIP the fan Belt & let them IDLE, until they thawed out.
Bill Cold
Old 01-11-2018, 01:43 PM   #20
Fred K-OR
Fred K-OR's Avatar
Default Re: advice
Could maybe use your wife's (friend's) hair dryer and that may warm things up a bit.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
