Old 10-09-2023, 11:45 AM   #1
stickshift
stickshift's Avatar
Default Missing bracket?
I said I would have a lot of questions, so here's another. On both sides of the car, there are sets of four holes that look like a bracket to tie together the rear of the apron to the rear fender goes there. It's not quite 90 degrees. Does anyone know the part number for Snyders or Langes? I couldn't seem to see the right one. Thanks in advance.
Stickshift
1915 Model T touring
1931 Ford Model AA Flatbed
stickshift is offline   Reply With Quote
Old 10-09-2023, 05:03 PM   #2
29spcoupe
29spcoupe's Avatar
Default Re: Missing bracket?
Rear fender to splash apron bracket. Part #4855
29spcoupe is offline   Reply With Quote
Old 10-10-2023, 10:14 AM   #3
Will N
Will N's Avatar
Is your Model T a 1915? I may be wrong, but I think that the bracket that goes along with those holes in the apron was not added by Ford until sometime after 1915. Your aprons may be reproductions that have the holes pre-drilled or originals from a post 1915 model that takes that bracket. I looked at the splash aprons Langs has, and the 14-15 does not have the holes, and the 17-25 does have those holes.
Will N is offline   Reply With Quote
Old 10-10-2023, 12:23 PM   #4
stickshift
stickshift's Avatar
I wouldn’t be surprised if my body parts are reproduction. I can see that the running boards and aprons are primed on the underside. I already ordered the brackets, so I’ll see how well they fit. I’m not sure if they should be bolted or riveted.
Stickshift
