03-24-2020, 08:53 PM | #1 |
1941 Ford Pickup Door window
Hope everyone is okay! Would like to know the best way to put a window back in a 1941 Ford Pickup passenger door! Thanks
Bob |
03-25-2020, 06:44 AM | #2 |
Re: 1941 Ford Pickup Door window
Remove the window regulator from the door amd leave it inside. The window get turned 90 degrees and dropped in from the outside of the truck. Takes some wiggling and easier with 2 people. Once you get it in position you slide it up and then slip the regulator on . While its apart grease the regulator and track.
Windows without the metal all the way around the glass are alittle easier. Not sure if that started in 41 or 42 |
03-25-2020, 09:19 AM | #3 | |
03-25-2020, 09:36 AM | #4 |
You might want to watch my videos. They will give you an idea of what to expect.
Mart. Pt1: https://youtu.be/QykFBWT33A8 Pt2: https://youtu.be/t0kf8yU1PWo Pt3: https://youtu.be/Ww-xUvlIyK4 Pt4: https://youtu.be/up1spE4RviI Pt5: https://youtu.be/Ne4CREsL1cE Can't believe I made that a 5-parter! Mart. |
03-27-2020, 09:22 PM | #5 |
Bob |
