Old 12-09-2012, 07:50 PM   #1
L78CHEVELLE
L78CHEVELLE's Avatar
Default 40 wheel out of round who repairs this? KY
I have one wheel on one of my '40 Fords that is out of round and bounces between 60 and 80 MPH. The wheel is dated and I want to keep it with the car. Does any one know a company that is good to repair this problem. I live in Kentucky.
L78CHEVELLE is offline   Reply With Quote
Old 12-09-2012, 09:30 PM   #2
Vergil
Vergil's Avatar
Default Re: 40 wheel out of round who repairs this? KY
Is it your wheel or tire? I had to have my tires shaved to true them up, what a difference.
Vergil
Bigger fonts to aid in reading
Vergil is offline   Reply With Quote
Old 12-10-2012, 07:22 AM   #3
ky29roadster
Does anyone around London shave tires to true them?
Bill
ky29roadster is offline   Reply With Quote
Old 12-10-2012, 11:10 AM   #4
sanborn
sanborn's Avatar
I had the same problem with my 40 several years ago. The solution wasn't the rim, it was the hub. Have you checked to make sure the rim is the porblem? And is it out of round or is it out of balance?
My problem was out of balance----and it only showed up at 60 - 80 MPH. I ended up stripping the hub down and putting in the lathe and machining away excess material on one side of the hub that caused the out of balance.
sanborn is offline   Reply With Quote
Old 12-10-2012, 12:15 PM   #5
L78CHEVELLE
I had four new Firestone tires and tubes put on the car from Cooker. When the wheel was placed on the balance machine without the tire the wheel was out of round. You could see the problem on the wheel when it was spun on the machine.
Old 12-11-2012, 01:42 PM   #6
sanborn
sanborn's Avatar
Your earlier description sounded just like a problem I had. You obviously were way ahead of me. Wish I could help you but I don't know of anyone who can repair it.
Old 12-16-2012, 11:34 PM   #7
lee34
lee34's Avatar
L78
There is a very good place in Louisville.They shaved my tires on the car..My wheel was a spoke wheel .They also balance your tire on the car (do not remove hub cap or any thing)They balance and check high speed operation as well.They are located on Poplar Level RD. The business name is Tonys. They are close to fair ground where the street rod nationals meet I get mine shaved and balanced when ever they are replaced.A bout 1 hour drive but worth it .Smoooooth , lee34
lee34 is offline   Reply With Quote
Old 12-17-2012, 12:11 AM   #8
deuce lover
deuce lover's Avatar
I suggest finding a replacement wheel.Sideways runout probably can be dealt with.Out of round nearly impossible.
