09-18-2019, 12:17 PM | #21 |
Re: Ignition timing
Thank you, Phillip, for making my point on terminology.
The left-hand (LH) points are adjusted first ... not the right-hand (RH). The position of the points is determined by the distributor being installed and viewed from sitting in the driver's seat. The LH side of the vehicle is always the left side. Not sure what instructions you are using, but I really don't think Bubba does it RH first. When you set the points (I think you're just mixing up LH/RH), how do you set the initial advance?
"Remember that when it comes to intelligence, half of all of us are below average." |
09-18-2019, 01:12 PM | #22 |
Re: Ignition timing
AGREED , THE MACHINE IS NICE BUT THERES MILLIONS SET WITH FEELER GAUGES. AND ALWAYS WILL BE.....
09-18-2019, 01:40 PM | #23 |
Re: Ignition timing
I'm not sure if Ford intended the pre 49 V8 points to be set with feeler gauges. I think they intended them to be set at a dealers on a setting fixture. That said, setting each pair to 15 thou will get the car down the road, and for any non performance application, the average driver would not notice anything wrong.
The next time I use my setting fixture I'll measure the points gaps and report what they are. For any non performance application, the lumbering old flatty is probably the least finnicky to things like dwell. Advance it until it pings and back it off until it doesn't. What they don't like is running retarded. I had a French flatty, with a distributor like a 8BA, vac advance only. The vac unit had failed, so I had no advance at all. The first long journey, (actually driving it home) it overheated after about an hour. Once everything was repaired it would run all day long. Mart. |
09-18-2019, 01:56 PM | #24 | |
Re: Ignition timing
Glad you jumped in , this thread is out of shape. Had surgery on my arm (for dialysis port) monday and just didnt want to type. I call these "thread drifts" thats when a thread or discussion just is full of non factual info. Good job hoop!!!!!!!! |
09-18-2019, 02:38 PM | #25 |
Re: Ignition timing
Bubba, a heap of blessings on your arm.
As you know, folks repeat what they think is correct. Let's pick on Mart ... he's a great contributor ... and examine what he posted in all good faith. "I'm not sure if Ford intended the pre 49 V8 points to be set with feeler gauges." As a matter of historical accuracy, let's look down below at Ford's patent for the helmet distributor. The original intent was for the operator/owner/mechanic to time the distributor using a "timing plate" (fixture) mounted on the "dash" (firewall) of the vehicle. The operator needed no special skill. It is a GUESS that a specified gap was set using feeler gauges but it was universal practice at the time. It is not mentioned in the patent but gapping points was as common as gapping plugs. Imagine Farmer Brown having to go into town to the dealer to have his points changed ... unlike his previous Fords which he did himself. Or, imagine Bonnie and Clyde bringing in their '34 Ford for a tune up. Here's a good read: https://patents.google.com/patent/US1963657A/en
"Remember that when it comes to intelligence, half of all of us are below average." Last edited by Hoop; 09-18-2019 at 03:39 PM. Reason: typo |
09-18-2019, 02:57 PM | #26 |
Re: Ignition timing
I did go on to say feeler gauges are probably as good as anything for most non performance applications. |
09-18-2019, 04:25 PM | #27 |
Re: Ignition timing
Right on Hoop. I was raised in my fathers shop when these were the king of the roads.
Not knittin pickin but most now their parents wasn't even born yet. We just got over very hard times WWII the ole man serviced many many Model A's pre war V8s. I still have the Standard ignition wall cabinet still loaded with points, condensers, rotors from the 30s and 40s. What I am trying to say back then No body but No body had a strobe, fixture, or the Sun machine that did it all. We were all mom & pop garages broke but better than picken corn. My fathers profit margin on a gallon of gas was 1 cent. But I always had good school clothes and toys. So customers for a tune up & oil change would come to any local garage. Guess they couldn't afford the dealer. So while I watched now embedded in my head pop took off the right top radiator hose (tin can catch water) remove fan comes right out with no hose in the way, remove distributor replace points set .015 replace all parts back on, then out the door. Thats the way I do it now and 70 yrs later, and my car runs perfectly. Not wise guy, but I find people now are all got their minds wrapped up with math and tech stuff. How many just used a match book cover to set points? from my generation, about every body when a simple feeler gauge was something in a Sears wish book LOL but true ........ |
09-18-2019, 04:37 PM | #28 |
Re: Ignition timing
My post is just my observations of what they appeared to do in the Ford factory ,maybe just a partial video
09-18-2019, 07:30 PM | #29 |
Re: Ignition timing
Hey big job, so one question. What is a matchbook?
Never mind I found them on ebay, used.
Enjoy yer day. Tom Hate can't fix what it started. |
09-18-2019, 07:58 PM | #30 |
Re: Ignition timing
I think this is why Big Job doesn't have a problem.
I have the Standard ignition wall cabinet still loaded with points, condensers, rotors from the 30s and 40s. |
