10-23-2018, 04:07 PM | #1 |
Oil change
Starting to get cold up here.
I’m gonna do an oil change. I know doing it when car is warmed up is best. What temp should I warm the car to?
Thanks - 30-9 1939, 1940 |
10-23-2018, 04:11 PM | #2 |
Re: Oil change
Operating temperature.
10-23-2018, 05:21 PM | #3 |
Re: Oil change
Then fill it back up with Walmart's new synthetic 0W-20 supertech like I do on my 21-studder for the winter. $16/5qts. Jack E/NJ
10-23-2018, 06:18 PM | #4 |
Re: Oil change
Jack
I always use rotollea 15/40. My engines are well worn/used - 40k miles But eagar to learn. Why do you use syn?
10-23-2018, 06:36 PM | #5 |
Re: Oil change
30-9 Drive the car a few miles to bring the oil up to operating temperature. Then drain and refill with the correct oil. You don't say if your engine is a new rebuild. Mine 8BA is not. I use 20W50. I would not recommend synthetic or the thin oil mentioned above on an old engine. It is my understanding that modern oils like 0W-20 are used on modern day engines built with very tight tolerances between moving parts.
Check out the info here: https://www.google.com/search?q=what...hrome&ie=UTF-8 Last edited by 19Fordy; 10-23-2018 at 06:43 PM. |
10-23-2018, 06:54 PM | #6 |
Re: Oil change
10-23-2018, 09:32 PM | #7 |
Re: Oil change
Hotter the better it drains. I'm nearby in northern NYS and use standard high detergent Penn 10W-30 year-round. Have no filter and change oil at 1000 miles.
10-24-2018, 01:50 PM | #8 |
Re: Oil change
I am with 19fordy , I run 20-50 in everything and have no reason to change.
Why would you run 0-20 it must be like kerosine and give low oil pressure readings and inadequate lubrication on the old jalopies. |
10-24-2018, 01:54 PM | #9 |
Re: Oil change
my4dv8: You are correct. My 2018 car uses 0W-16 oil with recommended oil changes every 5000 miles. The oil is like water. Future new oils will be even thinner.
10-24-2018, 03:57 PM | #10 |
Re: Oil change
>>>my old school thinkin.>>>0-20 it must be like kerosine and give low oil pressure readings and inadequate lubrication>>>
Not quite like kerosene. That's more like old school single weight oil technology thinking. 8^) Modern oils have additives that maintain more uniform flow viscosities throughout the temperature range of a running engine before its fully warmed up and add shear thickening strength at bearing interfaces where its needed most. Kerosene, diesel fuel & single weight oils don't behave like this. So in an old but refreshed 21-studder at fast idle, 0W-20 synthetic gives a fairly constant 20psi from cold start to warmed up. 5W-20 about 25psi cold gradually decreasing to 20psi warmed up. https://www.selectsynthetics.com/par...iscosity_Grade Jack E/NJ |
