10-02-2023, 08:37 PM | #1 |
Pressure plate mounting surface to flywheel surface distance
Perhaps a tiddly point, but what is the pressure plate mounting surface to flywheel friction surface distance supposed to be? I've seen 1.120", 1.123", and 1-1/8" (1.125"). I suppose there is some leeway that can be taken up in pressure plate finger adjustment, but I'm having my flywheel surfaced and I need to tell the machine shop something. Before resurfacing it's currently a fat 1.125" so I suspect the pressure plate mounting surface will need to come down some.
I'm thinking of telling the machine shop to machine it to 1.121"/1.125" (that is, 1.123" +/- 0.002"). Does this seem reasonable? Thanks in advance, as always.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
10-02-2023, 11:26 PM | #2 |
Re: Pressure plate mounting surface to flywheel surface distance
1.123 is exactly what 3 of mine measured.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
10-02-2023, 11:32 PM | #3 |
I have ground a couple hundred in a winona-van norman grinder. Always ground to 1.125. + or - .002 is just fine.
10-03-2023, 05:14 AM | #4 | |
If only the replacement clutch linings were a uniform thickness!! What do you suppose a thicker/thinner lining does for that number? . |
10-03-2023, 11:25 AM | #5 | |
Given that I'm already at 1.125"-1.126", I'm going to have the shop set the distance at 1.122"/1.125".
10-03-2023, 12:03 PM | #6 | |
10-03-2023, 04:05 PM | #7 |
Gee I wish I had seen
that print 40 years ago! The final step of checking and adjusting the fingers is what counts. |
